Well crap ... - Road Glide Forums
post #1 of 25 (permalink) Old 11-22-2012, 02:44 PM Thread Starter
HD_Shock's Avatar
Well crap ...
Finally found out where the slow leak on my rear tire was coming from.
Everyone seems to recommend replacing rather than patching mc tires but its such a small object (looks like a staple or similar), I'm wondering if a patch would ok in this case. Haven't pulled it out yet but It's only dropping about 10lbs in a weeks time. Only about 5000 miles on the tire (although its got a nice center flat spot already worn it already). So what's the consensus ... replace or repair?
-phil
2011 FLTRX 103
HD_Shock is offline
post #2 of 25 (permalink) Old 11-22-2012, 03:08 PM
2010 FLTRX's Avatar
I don't normally make this suggestion, but for your particular case I would just put a can of Ride On in there for the rest of that tire's life.
Sal - 2010 Vivid Black FLTRX
2010 FLTRX is offline
post #3 of 25 (permalink) Old 11-22-2012, 03:35 PM
bpt-bagger's Avatar
Replace it! You're life is worth way more then a couple hundred bucks. Just my 2 cents
bpt-bagger is offline
post #4 of 25 (permalink) Old 11-22-2012, 03:37 PM
laxinharley's Avatar
Agree with Bridgeport. Your life is worth more than saving a couple hundred. Especially with a flat spot as well.
laxinharley is offline
post #5 of 25 (permalink) Old 11-22-2012, 03:49 PM
chromedome's Avatar
With 5k miles on it I would replace it. Any excuse to get rid of the dunlops works for me!
2012 Road Glide Ultra & 2015 BMW R1200RT
chromedome is offline
post #6 of 25 (permalink) Old 11-22-2012, 03:51 PM
qkshift's Avatar
The other option is to hot patch it and I would install a tube for the rest of the tire life had the same kind of leak on a rk custom dealer said new tire I said bulshi- put on a new tube it was on the rear rode it 10000 more miles tube will give you peace of mind and a little more protection till you get some miles on the tire
qkshift is offline
post #7 of 25 (permalink) Old 11-22-2012, 04:00 PM
FLTRI's Avatar
Patch it (professionally) and ride on. It's not like the tire is damaged, it's a pin-hole...
I hate that motorcycle they make me ride. I'm here to tell you there ain't nothing in the world I hate worse than that elephant under my ass.
Officer John Wintergreen reference his Electra Glide.
-Electra Glide in Blue, 1973-
FLTRI is offline
post #8 of 25 (permalink) Old 11-22-2012, 04:10 PM
RoadieWingZ's Avatar
I'd pull the pin and put a tube in until time to replace tire because of wear. Tire looks like its got a lot of life and its highly unlikely that small pin hole is going to compromise the integrity of the tire. Plugging would require enlarging the hole which is a greater risk to the tire than that lil pin.
Road Glides Rule!!!
2009 Vivid Black FLTR, Gold Flame collection, Cee Bailey 18" TRSSC Dome, BOOM speakers, Kury FB extensions, Heritage Style bars
RoadieWingZ is offline
post #9 of 25 (permalink) Old 11-22-2012, 05:31 PM
mmcmsw's Avatar
tube it
If you don't have the road hazard insurance through your dealer, I would put a tube in it.
Trailers are for Boats!!
mmcmsw is offline
post #10 of 25 (permalink) Old 11-22-2012, 05:32 PM
tmd
I had a screw in my rear tire with about 4500 miles on it. I plugged it with a cord type tire plug. I'm almost at 9,000 miles and its holding well.
tmd is offline
