Just a friendly heads up - Page 3 - Road Glide Forums
post #21 of 40 (permalink) Old 12-25-2012, 10:59 AM
gsbuick65's Avatar
glad I found this, was working on bike in the garage with my work coat on and put fob in the pocket, come in hung coat up just inside door. next day, put on motorcycle jacket and went to work, went to leave work and bike wouldnt start, felt in pocket for fob no fob , thought i lost fob so had somebody take me home to get spare. well i just found the original thanks to this. now to change the code.
Mike Southaven Ms. 2011 RGU merlot, Rinehart true duals,Power Vision stage 1 a/c, Madstad shield, J&M 7 1/4's, Alpine KTP445U amp, CVO lowers.
gsbuick65 is offline
post #22 of 40 (permalink) Old 12-25-2012, 05:18 PM
X In Black's Avatar
Originally Posted by Big_gary View Post
Just Down loaded the app. It says its for the 09 models so not every thing will be the same for the 10s and up. Have not compared yet
Have you? Its a nice tool to have on your phone though. Thanks.
No, I haven’t compared everything. I like the PIN and Harley Dealer links, so that alone makes it worth having on my phone.
2012 FLTRX
Rinehart 2 Into 1|Ness Big Sucker AC|Andrews 57H Cams|PowerVision
X In Black is offline
post #23 of 40 (permalink) Old 12-25-2012, 05:54 PM
gtp01's Avatar
Don't have the reference yet for the iPhone.
gtp01 is offline
post #24 of 40 (permalink) Old 12-25-2012, 06:42 PM
Life Member With a Grey Beard
SharknoseScott's Avatar
Thanks for the heads up, OP. Just re-programmed mine and tried it out (works great; just took a while for big-thumbs to get it right). Now I just gotta also be sure I don't forget it all (picked numbers I knew I would remember, it's just the sequence of stuff).
Another useful forum post!
Once I make up my mind, I'm full of indecision.
SharknoseScott is offline
post #25 of 40 (permalink) Old 12-25-2012, 08:26 PM
mmcmsw's Avatar
that app is worth its weight
I love that app. Saw a Ultra Classic limping on the way to Sturgis, near Blue Earth, MN. Pulled out my phone, called up the codes, located a dealer, called the dealer, with the ECM code, they had the part, helped the ultra download the app, he called a tow truck, and headed to Albert Lea, for repairs, and I headed off to SD.
When I asked him what codes he was showing, he had no idea what I was talking about. The V twin app tells you how to call up the codes and cross reference them. The new improved version is most awesome.
Trailers are for Boats!!
mmcmsw is offline
post #26 of 40 (permalink) Old 12-26-2012, 03:39 PM
Another idea - I ride with the same group of guys almost all of the time. We have all programmed our pin number the same. That way when we are on a trip and we have to move one of the bikes and the rider isn't right there, it makes it real easy. On the negative side, we can really screw with one another too! Not that we have done that!
nygader is offline
post #27 of 40 (permalink) Old 12-26-2012, 04:08 PM
RoadGlideRider's Avatar
Originally Posted by X In Black View Post
There’s an app called “V Twin Reference” on Google Apps that has a section on it called “Security Pin Menu”, among many other things. Instructions on Security PIN Override, Reset and Transport. I just put a text file in my file folder with my PIN code and use the apps instructions. Very handy. I have it on my Android phone. Not sure about Windows or iPhones.
It is for the Android Only.
Originally Posted by LittleMoe View Post
Would the info in that app also work for my 06??
I did a Google search. They have separate V Twin reference for 2007, 2008 and 2009 only. But there is nothing I found that is directly linked to '06/earlier or '10/later.
RoadGlideRider is offline
post #28 of 40 (permalink) Old 12-26-2012, 04:56 PM
ejones642's Avatar
I actually use my code frequently. Especially when I'm moving it around in the garage/yard or for the occasional bath. Though maybe only a little, I can also imagine it helps conserve the battery in the fob as well.
ejones642 is offline
post #29 of 40 (permalink) Old 12-26-2012, 05:03 PM
The FOB is transmitting at all times with the '07/later passave systems. So you are not saving the battery.
post #30 of 40 (permalink) Old 12-26-2012, 11:16 PM
ejones642's Avatar
Though I won't dispute your claim(I'm not a H-D engineer), I do find it ironic that I've noticed batteries installed at the same time have different lengths in life. And I typically carry one more than the other(alternate from time to time) and the one I carry the most always starts dying first. Just an observation made on several bikes.
