Does anyone know which side of the ignition to put the accessory switch block that comes in the kit on, and in which of the 3 locations to put the fan button? The rest of the fitting instructions are pretty good, but when it comes to fitting the switch there is no information...............2017 Road Glide Special
The switch block and shiches that come with the kit take the place of the dummies that are shown in the attached photo. There is a harness that leads to bottom of both sets of switches, either side of the ingntion. The buttons on the switch block were loose in the box when supplied, and can fit in any combination. My question is which side of the ignition does the switch block go on, and which one of the three availabe slots in the switch block does the fan button go in?
Do you mean that the whole switch block (with 3 swicthes) is the set that should be located on the right hand side of the ignition, or that the button should be the far right of the 3 in the swith block?
1. Which side of the ignition is the correct position for the CoolFlow Fan switch block
2. Which slot in the switch block (of 3) should the Fan Switch be located? Left, Middle or Right?
Sorry, I'm still confused! There are two sets of switch blocks, each contain 3 switches. One of them is on the left of the ignition switch and the other on the right. I need to know that the switch block goes on the right or left of the ignition, and then which position on the switch block to position the Fan button in.
Example: Switch block to right of ignition, and button on left.......... Please if you know?
I don't think it matters which side of the ignition you put it on but based on the fact that your left hand is freer to momentarily remove from your handlebars, putting it on the left side makes more sense.
Some of these pics (and descriptions) may help, this is from when I added the DayMaker LED driving lights. The left and right blocks are different anyway-so you cannot switch side even if you wanted to:
during a ride in the December cold weather the button for the coolflow fan switch evidently popped off my switch.
didn't realize it until a few days later when going out for another ride.
dealer says they are still on backorder; says they are re-engineering the switch so it doesn't pop out of the unit.
expects something will be shipping in mid-March.
has anybody else had this problem?
how did the dealer handle it?
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
