clutch cable replacement - Road Glide Forums
 7Likes
post #1 of 14 (permalink) Old 04-16-2017, 09:22 AM Thread Starter
Do I need to drain the trans ?
MarkL is offline
post #2 of 14 (permalink) Old 04-16-2017, 09:50 AM
Desertwndrr's Avatar
No. You will lose some oil, but not too bad. Make sure that you are on the kickstand and not a lift holding the bike straight up.
MightyWhitey and MarkL like this.
2012 FLTRX 124", 2015 FLTRXS, 2016 FLTRXS, 2004 FLSTF, 2006 FLSTFSE, 2007 FXSTSSE 124"
Desertwndrr is online now
post #3 of 14 (permalink) Old 04-16-2017, 10:02 AM
MightyWhitey's Avatar
Desertwndrr is right. However, it is a perfect time to drain and refill with some redline heavy shockproof. Mine has never clunked less. Just sayin'.
slowglide2989, madmat and MarkL like this.
MightyWhitey is offline
post #4 of 14 (permalink) Old 04-18-2017, 09:10 AM
stackrat's Avatar
I just did mine and I regret not draining the trans first. I ended up draining it anyway and putting in new fluid. Like Whitey says, its a good opportunity to but something better in there.
2012 RGU
stackrat is offline
post #5 of 14 (permalink) Old 04-19-2017, 05:33 AM Thread Starter
Yes , I wish I had drained it first but live and learn lol .
MarkL is offline
post #6 of 14 (permalink) Old 04-19-2017, 09:09 AM
Why are you replacing the clutch cable did it break? Why not drain the trans it only takes a quart of oil.
post #7 of 14 (permalink) Old 04-19-2017, 04:10 PM
stackrat's Avatar
I can't speak for MarkL, but I had to replace mine with a longer one for my apes.
2012 RGU
stackrat is offline
post #8 of 14 (permalink) Old 04-19-2017, 06:02 PM Thread Starter
I just got my bike a couple of months ago and it has a salvage title . To get the bike titled and on the road in Michigan it has to pass a tough safety inspection . Upon the first inspection among several other things the inspector seen a gouge in the outer coating of the cable . It still functioned fine but they said it was a safety issue ( whatever lol ) . Just a few weeks ago I just changed the oil in all 3 holes and so was asking if I could get by without draining the trans . I did just end up completely draining it again and refilling it with new . Plus before I drained it I took the cover off and it ran down on the bottom of the motor . Thats the long drawn out story .
MarkL is offline
post #9 of 14 (permalink) Old 04-20-2017, 07:01 AM
I'm from Michigan and lived most all my life there and I never knew that they had such a inspection procedure for salvage title motorcycles. It sounds like they want the bike to be just like a new bike not only in function but in looks as well, sounds like a PIA good luck.
MarkL likes this.
post #10 of 14 (permalink) Old 04-20-2017, 08:50 AM
Here in CT it's the same thing with a salvage title. They want to inspect it with a microscope and want receipts for everything that needed to be repleced in order to make it drivable again plus VIN#'s from the bike the parts came off of if they were taken from another bike. Salvage titled vehicles are a real pain in the ass here.
rlaf75 is online now
