Brake & Clutch Lever Install - Road Glide Forums
post #1 of 4 (permalink) Old 08-03-2011, 09:04 AM Thread Starter
jimmyray11349's Avatar
How difficult is it to remove & install Brake & Clutch levers? I can not find it in service manual.
I want to put on black. Does anyone have black take-offs for sale?
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #2 of 4 (permalink) Old 08-03-2011, 09:09 AM
BDMastiff's Avatar
It's not that difficult to replace the levers. Loosen the clutch cable all the way. There is a pin that holds the levers in the perch. Use some snap ring pliers to remove the snap ring and pull the pin out. Then pull the lever out of the perch. The rest is self explanatory. I feel as if I'm forgetting something but it's an easy job. If you're mechanically inclined it should be a piece of cake.
1996 Fatboy
BDMastiff is offline
post #3 of 4 (permalink) Old 08-03-2011, 10:14 AM
Redfish-Joe's Avatar
All he said but be careful of the brake light switch. Easy to damage.
Redfish-Joe is offline
post #4 of 4 (permalink) Old 08-03-2011, 11:29 AM
BDMastiff's Avatar
Yes, what he said.
1996 Fatboy
