Helmet concerns - Page 3 - Road Glide Forums
Helmets Anything and everything to do about Helmets!
post #21 of 25 (permalink) Old 10-27-2012, 08:24 PM
eme56's Avatar
I have this on the saddlebag guard. It was actually cheaper than the aftermarket ones, which was a surprise.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
post #22 of 25 (permalink) Old 10-31-2012, 10:41 PM Thread Starter
Life Member With a Grey Beard
SharknoseScott's Avatar
Thanks; great tip!
Once I make up my mind, I'm full of indecision.
SharknoseScott is offline
post #23 of 25 (permalink) Old 11-14-2012, 12:05 AM
Originally Posted by RGCBandit View Post
I use this so I don't lose a $600 helmet anywhere...
http://www.bestrestproducts.com/c-159-helmetlok.aspx
Cheap insurance, easy to use, easy to stow, and has other uses as well.
I've actually got one of the HelmetLoks and for the life of me, I can't find a place that either one of these locks will fit on a FLTRX and still be able to hang my full-face helmet. I can attach it to the fairing brace coming off the engine guard but the helmet is really crammed up in that slot between the wheel and the engine guard then and my face shield would be damaged. I can't fine another single spot to hang it though.
illwill is offline
post #24 of 25 (permalink) Old 11-14-2012, 09:37 AM
chromedome's Avatar
I had a half helmet jacked in a motel parking lot in Morro Bay, Ca.
I was an idiot and forgot to take it into the room overnight.
I gotta think there is some bad ju ju associated with riding in a stolen lid.
I sure hope so anyway!
2012 Road Glide Ultra & 2015 BMW R1200RT
chromedome is offline
post #25 of 25 (permalink) Old 11-14-2012, 02:36 PM
LeotheThird's Avatar
Ok, I've had the Helmet lock from HD on 2 bikes on the Engine Guard and here's where I placed mine.
I've seen others where they have placed it facing forward but down near the highway peg. This gives you plenty of clearance from the ground and since the front wheel is turned towards the left away from the right side of the engine guard you have clearance there also. And I haven't had anything to worry about coming in contact with the faceshield. Hope this helps you.
LeotheThird is offline
