Flashing red signal - Road Glide Forums
Safety Area Issues and articles related to safety.
post #1 of 13 (permalink) Old 08-22-2012, 06:46 PM Thread Starter
Flashing red signal
When you come up to a four way intersection with only one light hung by wire in the center of the intersection and it is a flashing red WATCH OUT. Not all states are the same on this issue. In Minn. I believe all four ways flash the same. Because the light is in the center it can be hard to see what side trafic is required to do and you get programed to the rules of your home state. I was in upper Michigan stoped for a flashing red light, pulled out and had a WTF moment. Other states chime in, how common is this that one direction will have a flashing red and side trafic have a flashing yellow.
roadglidetouring is offline
post #2 of 13 (permalink) Old 08-22-2012, 07:31 PM
qkshift's Avatar
have some of those in the country but those or two way stops that have more traffic just to get the oncoming traffic to slow down and use caution
qkshift is offline
post #3 of 13 (permalink) Old 08-24-2012, 09:24 PM
Tyler Durden's Avatar
For a single flashing red, I think it is common for signs to be placed as well. So, I'll look for whatever sign cross traffic might have...and if I don't see one, I'm not going anywhere until I see it safe to do so.
I'm from Michigan, and this has always been habit for me to check for the cross traffic and any signs. But I think it is probably best to assume the cross traffic has the right of way when you have a flashing red.
Tyler Durden is offline
post #4 of 13 (permalink) Old 08-24-2012, 10:34 PM
Here in CT i think it depends on the intersection really.
rlaf75 is online now
post #5 of 13 (permalink) Old 10-31-2012, 07:03 PM
opr1945's Avatar
I'm from western Michigan and blinking lights with red on one side and yellow on the other, are all over the place. thought it was like that everywhere.
opr1945 is offline
post #6 of 13 (permalink) Old 10-31-2012, 09:45 PM
idahointrudr's Avatar
Thats interesting. I have never seen that before. I have only seen all four sides blinking.
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #7 of 13 (permalink) Old 10-31-2012, 10:07 PM
If its flashing red for me, I'm going to stop then proceed with caution no matter what the other side is doing, I've seen so many people run 4 way stops until I never assume they are going to stop.
post #8 of 13 (permalink) Old 10-31-2012, 10:39 PM
HarleyLance's Avatar
We have them here in WA state. I've usually seen them with a sign that says something like "Cross traffic does not Stop." If it's flashing red for me, I stop then proceed with caution.
2010 Road Glide Custom FLTRX Scarlet Red - SE Stage 1 AC, Carriage Works Tornado Slip-on, SE SuperTuner, Jagg Fan Assisted Oil Cooler, 12" Windvest, HD Chrome Saddlebag Guards, Arc Audio MPAK 6
HarleyLance is offline
post #9 of 13 (permalink) Old 10-31-2012, 11:13 PM
RGCBandit's Avatar
+1
I always come to a complete stop, and check all directions for the all-clear before proceeding.
2012 Road Glide Custom Black Denim
RGCBandit is offline
post #10 of 13 (permalink) Old 11-11-2012, 09:05 AM
fossil mel's Avatar
In the past, many locales in MN especially the rural areas had flashing 4 way lights at intersections. They all did not flash the same color. Many intersections had flashing yellows for the main thoroughfare, and flashing reds for the intersecting side street.
Over the years, the flashing lights have been replaced with stop signs for the side streets. On streets were there have been a significant amount of crashes, the stop signs have red flashing LED's around the perimeter of the sign to draw the driver's attention to the sign.
fossil mel is offline
