Power Vision map for dragula 2/1 and TR-555 TRQ Cams - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 9 (permalink) Old 03-27-2012, 11:08 AM Thread Starter
TXcruiser's Avatar
Howdy.. anyone have a map for the power vision that would get me started and good enough to make it to the tuner?
2012 Road Glide
103" stock motor
Dragula 2/1 Exhaust
SE Ventilator A/C
Tman 555 torquester cams
Thx in advance if anyone can help!!
BTW - we need to start using this section of the forum more
'12 FLTRX
TXcruiser is offline
post #2 of 9 (permalink) Old 03-28-2012, 02:09 AM
did you get the PV from fuelmoto? Either way, Jamie may be able to help you out
2009 Crossbones-black denim
2012 Road Glide Custom-black denim
brettnbama is offline
post #3 of 9 (permalink) Old 03-28-2012, 11:46 AM Thread Starter
TXcruiser's Avatar
Yes I did. I'll be checking with Jamie also, I'm sure he can get me pretty close.
'12 FLTRX
post #4 of 9 (permalink) Old 03-29-2012, 05:01 AM
he sent me a map that seems to be close. a little popping sometimes. I plan to do some data logging when I get back to the states this fall. I think the T-man 555 cams are close enough to the Woods that Jamie probably has something
post #5 of 9 (permalink) Old 03-29-2012, 08:20 AM
I wish I could help you. I dont have a map for the Power vison with those cams.
I do have a real map for the stock motor and Dragula....... for Power Vision....
If it were a any other tuner I could help.... you.
I can send you a map from a tts and you can try the VE tables etc. and see if it will work on the PV you just need to enter the data by hand 1 at a time and try it. should be real close.
The Tman 555 tq cam and Woods 555 are not the same.
If your close to me I would love to tune it for you.
Your best bet is have some one tune it....... canned maps only go so far.....
You can call Dyno Jet and see who is good in your area with a PV...
DragoBikeWorks is offline
post #6 of 9 (permalink) Old 03-30-2012, 07:09 AM
Frank, do you have a map for the 103" with the Dragula?
post #7 of 9 (permalink) Old 04-02-2012, 11:41 AM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
While I do not have an exact map for this pipe and cam I would be more than happy to put something together for you to get you started. You can also mount the PV display and do some data logs which will allow you to easily generate a new tune, or you can send me your logs and I can do it for you and email you a new tune. You cannot take tables from a TTS or other calibration and enter them into the PV map as there are very different things going on in the background with the "structure" of the calibration. Send me an email to jamie@fuelmotousa.com and I can help out no problem
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #8 of 9 (permalink) Old 04-02-2012, 01:42 PM
Yes email me
dragosbikework@yahoo.com
post #9 of 9 (permalink) Old 04-03-2012, 01:20 AM
email sent, thanks!!!
