Oil Bud Cooling - Road Glide Forums
post #1 of 14 (permalink) Old 10-20-2012, 08:35 AM Thread Starter
jacknife's Avatar
Oil Bud Cooling
Well I have done a search with no results. Just curious if anyone here is using one of these oil coolers or if anyone has tried one & didn't like it?
Very pricey, but if they work as well as claimed it maybe a good investment.
http://harleyoilcoolers.com/
Any advise or thoughts.
2013 Road Glide Ultra Midnight Pearl
jacknife is offline
post #2 of 14 (permalink) Old 10-20-2012, 08:55 AM
staush's Avatar
Yours doesn't have one already?
staush is offline
post #3 of 14 (permalink) Old 10-20-2012, 09:08 AM Thread Starter
jacknife's Avatar
Yes it has the small factory oil cooler, just looking for something better. I do alot of mountian riding usually two up with the wife, looking around at slower speeds eliminating alot of air flow. I am around 285-295 & with her & crap in the bags the bike is packing a load Lol.
jacknife is offline
post #4 of 14 (permalink) Old 11-05-2012, 08:20 AM
FLTR2008Trike's Avatar
I have one on my 117" triked Roadglide. The Oil Bud cooler works!!! It is as tough as they claim and will reduce your engine temps. I recommend it to anyone who wants a tough oil cooler that does cool your engine oil temps
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #5 of 14 (permalink) Old 11-05-2012, 12:47 PM
I put one on my 04 bagger with a built 107" and it worked as advertised . Well built,easy to install and really made well. A little pricy but well worth it.
Thistle
2012 FLTRU ,Ember Red Sunglo, painted inner fairing, WO 515 Chubby bars, 14"and 16" dark smoke Windvest, J&M 6 speaker Rokker system w/ 500W amp, Zumo 665 Road Tech G.P.S. w/Iron Aces mount, Mustang "Super Touring w/backrest, Fuel Moto air cleaner,2-1-2 headpipe, SuperTrapp 4" Stouts, Wood WT555 cams, Wood lifters, SE adjustable push rods,Power Vision tuner, Foorboards moved out 1" and forward 1"
Thistlethunder is offline
post #6 of 14 (permalink) Old 11-05-2012, 06:16 PM Thread Starter
jacknife's Avatar
Nice to hear some good reviews, Thanks. I have decided it will be on my list to do this winter along with a Baker +1.5 oil pan I think will be a major improvement.
jacknife is offline
post #7 of 14 (permalink) Old 11-05-2012, 06:33 PM
jimmyray11349's Avatar
I have the Jagg 10 row Fan Assisted and it does a great job. my bike cruises 1 or 2 up at 75-80 mph and temps range from 190- 205, even in the hot summer months. I think my temps dropped 25 degrees when I added the Jagg. Worth the money. $400 from Direct harley parts.
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #8 of 14 (permalink) Old 11-05-2012, 07:20 PM
tmd
Believe it or not but those temps are perfectly normal and your engine is actually designed to run that way. Spending all that money on a different cooler and oil pan may lower the temps a few degrees but in the end there is no real advantage and you will be left with a lighter wallet. Think about this for a minute. H-D is cranking out almost 300,000 bikes a year. A majority of them stay bone stock except for maybe and air cleaner and pipes and they run for tens of thousands of miles without issue.
Of course reading these fourms you would thing the sides of the roads were littered with twin cams with melted engines becuase you didn't spend a bunch of money on unnecessary accessoried to make your engine run cooler.
Ride the bike the way it is and spend that hard earned money on more important things like chrome.
tmd is offline
post #9 of 14 (permalink) Old 11-15-2012, 09:58 PM
Coming back from Sturgis in 2011 we were runing the bikes 70-75mph in 108* temps (I live in Las Vegas) on Interstate 15. The bike did quite well, no issues, however after that I installed Harley's Premium oil cooler and cutted the "CAT"...I feel much better about it all now. The winter mods I'll be doing will insure the bike will run even cooler.
post #10 of 14 (permalink) Old 11-16-2012, 05:47 AM
smitty901's Avatar
If you already have a stock HD oil cooler why not give this a try it worked for me.
Cost is not to bad easy to install and works
http://bigskyfan.tripod.com/id10.html
smitty901 is offline
