07 tourpak - Road Glide Forums
post #1 of 4 (permalink) Old 01-06-2013, 07:34 PM Thread Starter
ribman's Avatar
07 tourpak
i finally found an 07 tourpac on craigslist with rear light assembly.i have an 08 rg.the pak has a three prong connector. does my bike have a connector that will tap into this? i cant find a matching plug under the seat
ribman is offline
post #2 of 4 (permalink) Old 01-06-2013, 07:59 PM
your plug for your tour pak should be on the left side (asyou set on bike) . under the plastic side cover . at least it was on my 12 rg
craig demel is offline
post #3 of 4 (permalink) Old 01-06-2013, 09:23 PM Thread Starter
ribman's Avatar
meant to say 98 rg. but i found the connector exactly where you said.. thank you craig.
ribman is offline
post #4 of 4 (permalink) Old 01-06-2013, 10:22 PM
RoadGlideRider's Avatar
I made a short extension so the plug was just outside the Tour Pak.
I have the Detachable rack and makes it easy to remove and replace.
RoadGlideRider is offline
