Battery tender - Road Glide Forums
post #1 of 11 (permalink) Old 07-29-2013, 07:38 PM Thread Starter
crossbonesglide's Avatar
Battery tender
So after charging all night the light still shows charging. It's never taken that long to charge. The battery isn't a year old yet, I'm thinking the tender may be bad.
crossbonesglide is offline
post #2 of 11 (permalink) Old 07-29-2013, 07:55 PM
Tourhog's Avatar
Had same issue once. It turned out to be the pigtail hooked up to the battery was bad. Not the charger or battery.
2013 RGU BBP
Tourhog is offline
post #3 of 11 (permalink) Old 07-29-2013, 07:58 PM
Bull_Duck's Avatar
If the charger lights on, then likely ok. Loo to your battery connection. All the terminal connections + & -, not only trickle charger.
Bull_Duck is offline
post #4 of 11 (permalink) Old 07-30-2013, 01:42 PM
CSM11's Avatar
I agree check connections
CSM11 is offline
post #5 of 11 (permalink) Old 07-30-2013, 02:23 PM
PGR
PGR's Avatar
Depends on which version you have. I have the HD version.
Flashing Amber = Disconnected
Solid Amber = Begin charging
Flashing Green = Almost charged
Solid Green = full charge
Ron..........................
PGR is offline
post #6 of 11 (permalink) Old 07-30-2013, 02:36 PM
www.hogpro.com
HogPro's Avatar
Some pigtails have fuses in tehm. Check the fuse.
HogPro is offline
post #7 of 11 (permalink) Old 07-30-2013, 03:13 PM
moose1's Avatar
I had a battery on my 2011 heritage go bad at about 6 months old and it cooked my battery tender
Sent from Motorcycle.com App
2012 FLTRU vivid black
moose1 is offline
post #8 of 11 (permalink) Old 07-30-2013, 03:17 PM
throttles&triggers's Avatar
Unplug the tender from the outlet or extension cord and plug it right back in. The light should go to green if it is charged, if not something may not be connected properly, most likely at the battery. If your connections are all good, it could be the battery tender.
The other option is that you have a bad regulator and there was a VIN recall on those. That should be looked into, as well. My tender did not indicate a full charge until the regulator was changed out under warranty.
throttles&triggers is offline
post #9 of 11 (permalink) Old 07-30-2013, 04:10 PM Thread Starter
It is the HD battery tender. It worked last week with no problems. This week solid amber for 12 hours. Pulled the fuse and the amber flashed, replaced the fuse and checked all the connections, all tight. Is there a way to check the voltage with a voltmeter from the tender without killing myself? Don't think the battery is already bad on a 2013 model.
post #10 of 11 (permalink) Old 08-01-2013, 11:36 AM Thread Starter
After giving it a couple more hours yesterday it finally turned green.
