Sirius Stratus 6 install - Page 4 - Road Glide Forums
post #31 of 44 (permalink) Old 11-08-2012, 01:13 PM
RoadGlideRider's Avatar
Originally Posted by mitchdm View Post
I use my phone. Has GPS, Sirius, and Phone Can plug into the aux & or bluetooth to my helmet ~ Had a zumo 550 on the Ultra with HD's xm box. Worked great but figured I'd attempt to save a few bucks with this setup for now. I mounted the phone under the baseplate of the MadStad with the samsumg car mount ~ Slightly modified... I'll shoot pics later.
I could do the same with my IPhone. Even save by dropping Sirius and use only Pandora.
But it is only good in areas with good Cell reception. It uses the cell towers to operate.
Traveling you may loose reception, or be set in the "Roaming" mode and cost extra money.
But if you never travel away from your Home area, it is great. I like to ride around and tour on my RG.
RoadGlideRider is offline
post #32 of 44 (permalink) Old 11-24-2012, 07:24 PM
Eddie-Diesel's Avatar
Smile Stratus 6
I mounted the unit with heavy duty velcro above my speedo also. I zip tied the antenna wire to my brake cable and mounted the antenna on the right side of my windshield with the velcro also. This allows me to remove both to clean the bike. It works great.
Eddie-Diesel is offline
post #33 of 44 (permalink) Old 01-01-2013, 11:05 AM
Jay2Beers's Avatar
Thumbs up Sirius !!
I believe THIS will be my next and soon Project!! Cool!!
'13 Blk RGC crs/abs/sec 103 Stg2 255cam-plus D&D Boss Fatcat SE Super Tuner. Klockwerks 12", Blk 10"Chubby w/Blk Get-A-Grips. Skunked Day Maker. CD GEN2001157Amber/Wht Front & Red Rear Smoke Lens w/Magic Strobe & bits more, Always a WIP
Jay2Beers is offline
post #34 of 44 (permalink) Old 01-04-2013, 10:50 AM
Clutch1's Avatar
I put my Sirius radio in the left side pocket on velcro and ran the input wire to the aux through the fairing and put the antenna on the radio under the fairing as well. I dont change radio staions much but the remote works well in wifes hands lol. Im a bit cheap lol.
Clutch1 is offline
post #35 of 44 (permalink) Old 08-29-2013, 04:33 PM
sdjiggs's Avatar
how is it handling the vibrations?
sdjiggs is offline
post #36 of 44 (permalink) Old 08-29-2013, 07:11 PM
jack6hd's Avatar
No problems. Enjoy.
2015 FXDL 2nd best HD on road
jack6hd is offline
post #37 of 44 (permalink) Old 03-10-2014, 08:03 PM
Jay2Beers's Avatar
Very cool mount! I'm doing this as I type,.... And easy.
post #38 of 44 (permalink) Old 03-24-2014, 05:50 PM
I just bought the Alpine 149BT which is Sirius XM ready, so I bought a Sirius XM kit, I have two amps mounted on my radio so I don't know if there will be any room left for the antenna, I guess I'll find out soon, I'm just wondering if anybody has mounted that little antenna anywhere else. I have seen a "motorcycle" kit, but I definetly don't plan to use that kind of antenna if I can avoid it.
post #39 of 44 (permalink) Old 03-24-2014, 05:56 PM
Mark62's Avatar
Post
Very clean! Looks like it belongs there!
2013 RGU Vivid Black / SE 204 Cams / SE Heavy Breather / SE Super Tuner / Most chrome PC Blk / Reinhart Black slip ons / Black Ice Wheels / De-Cat Header / Pow-Mia Theme in remembrance of my Papa Joe, U.S.S Houston.
Mark62 is offline
post #40 of 44 (permalink) Old 04-15-2014, 06:20 PM
Thumbs up Great idea, thanks for sharing...
Originally Posted by flg8r71 View Post
Since the antenna is magnetic I stuck it to the top of the radio underneath the fairing. The only time I've had signal loss is when I've been riding on roads that have a thick overhead canopy from trees. I'm going to install J&M Rokkers soon and an amp so I'm going to have to move it but for now this has worked very well.
Cool! I've been thinking about putting a Sirius Onyx in one of the gloveboxes. I don't recall seeing an AUX input hanging, how did you wire the Sirius to the head unit? Do you think it would work to mount the antenna above the headlights?
MidNightRGU is offline
Tags
iron aces , mount , satellite , sirius
