Just ordered the Legend Air Suspension... - Road Glide Forums
post #1 of 16 (permalink) Old 11-28-2012, 07:14 PM Thread Starter
Chicago Harley Boy's Avatar
I will send pics and updates once installed! Stay tuned.
DIABLO- 2012 Ember Red Sunglo Road Glide Ultra
Chicago Harley Boy is offline
post #2 of 16 (permalink) Old 11-29-2012, 02:01 AM
I can't remember if the RGU has an empty spot on the instrument panel or not. If there's an open spot You should look at a CVO tour pack power lock switch. It's a three way switch and can be wired as the control for your legend air. It looks way better than the switch that legend sales.
steve_s is offline
post #3 of 16 (permalink) Old 11-29-2012, 09:42 AM
CHAINSAW's Avatar
Please create new threads in the correct sub catagory - moved to the suspensions subforum
Such is the rule of honor.
CHAINSAW is offline
post #4 of 16 (permalink) Old 11-29-2012, 10:04 AM
Fire-Medic's Avatar
Don't know about the older bikes, but mine does not. Another trick would be to move the factory one for the trip meter, and mount it between the odometer and RPM gauge down low, will look factory. And then this would free up a slot on the panel for a switch like the one you describe.
Fire-Medic is offline
post #5 of 16 (permalink) Old 11-29-2012, 07:03 PM Thread Starter
Great ideas. I wanted the switch on the handlebar so I could adjust while riding. I will figure out a solution and let you know. I also have to find a spot for it because since i have a handlebar mount gps it won't fit on the left side of the bars.
post #6 of 16 (permalink) Old 11-29-2012, 07:53 PM
here is where I put mine. I love my legends.
2011 Sedona Orange FLTRX, 124" S&S, D&D Boarzilla, 66mm Thottle Hog, Streched and Custom
piesik650 is offline
post #7 of 16 (permalink) Old 12-02-2012, 02:07 PM
piesik650 are your legends the 12 inch or 13 inch? you said you loved them, can you tell us a little about them? hows the ride? hows the install? etc.
nanook is offline
post #8 of 16 (permalink) Old 12-02-2012, 06:12 PM Thread Starter
Nice Piesik.....do I need to change my kickstand? I just thought about that. What if I want to lower it all the way while parked? Thanks
post #9 of 16 (permalink) Old 12-02-2012, 06:14 PM
Fire-Medic's Avatar
You could, or you could heat yours up and bend it.........
post #10 of 16 (permalink) Old 12-03-2012, 09:29 PM
yamahoe72's Avatar
I used the CVO switch also.
2012 Road Glide Custom, Denim black, 14" Carlini Evil Apes, V&H Dresser Duals, Rhinehart slipons, Air Ride, Banana Boards, PM shift & brake levers, Cyclesounds speaker lids, Sony MS60, JL amps, Hertz HCX's, Meancity Cycles seat, lots of black
yamahoe72 is offline
