True Track - Road Glide Forums
post #1 of 7 (permalink) Old 11-29-2012, 06:05 PM Thread Starter
True Track
It seems as a new person to this forum that most of the bikes appear to be pretty new - 2009 and newer. Just bought a 2003 anniversary Road Glide and am wondering if it is worth the money to invest in a True Track setup. I am wondering if any of you have, or have had an older Road Glide with this installed. Any advice is much appreciated!
rfullmer is offline
post #2 of 7 (permalink) Old 11-29-2012, 06:23 PM
I did the "missing link" on my 03 Ultra and 05 Road King......the difference is noticable and they were MUCH more stable. At 2 up or high weight its more noticable, in a word....yes it makes a difference. Do your homework though, not all links are created equal. I chose the missing link because it replaced the swingarm pivot bracket, rather than adding a bracket to a frame stiffener. I believe that it is stronger there....JMO mind you. I also liked that the pivot point on that model was in line with pivot point of the swingarm. I havent looked at any of them lately, but True-Track is the ONLY one who makes one for my ol'girl, I havent bought one yet, but Ester is much more stable with the late model swingarm.
Hope this helps.
1989 Tour Glide "Ester"
Desertkowboy is offline
post #3 of 7 (permalink) Old 11-30-2012, 10:30 AM
teejay's Avatar
I installed the Progressive Chassis Stabilizer on my 2001 and the improvement was noticeable.
teejay is offline
post #4 of 7 (permalink) Old 11-30-2012, 12:03 PM
2000 FLTRSE1, added progressive set up because the wheel dock center stand still fit. I like the solid feel with it.
Jayray is offline
post #5 of 7 (permalink) Old 11-30-2012, 12:12 PM
Progressive Touring Link here. The Progressive Touring Link works great, it is a easy install and you don't loose any of your ground clearance you can still use a center stand if you want and it cost $200 (it did when I got it) and that is about 1/2 the cost of other stabilizer systems.
ironmark is online now
post #6 of 7 (permalink) Old 11-30-2012, 05:09 PM Thread Starter
Thanks!
Thanks to all that replied. It looks like I need to do some homework between True-Track, Progressive, and potentially others. I plan to get one of the systems in December so once again thanks.
rfullmer is offline
post #7 of 7 (permalink) Old 11-30-2012, 05:39 PM
rageglide's Avatar
Another True-Track vote. Helps a ton IMO.
rageglide is offline
