2013 Fork Oil capacity - Road Glide Forums
post #1 of 9 (permalink) Old 06-03-2013, 06:15 AM Thread Starter
torqu's Avatar
Just wondering what the capacity for each fork is supposed to be . I changed over to black fork legs and I cant get a straight answer. I've been hearing 10.7 or 10.9 does that sound right?
torqu is offline
post #2 of 9 (permalink) Old 06-04-2013, 12:43 PM Thread Starter
torqu's Avatar
Forget it. I just poured 315ml in it and called it good.
torqu is offline
post #3 of 9 (permalink) Old 06-04-2013, 12:50 PM
10.8 fluid oz or 319 ML per fork tube.
post #4 of 9 (permalink) Old 06-04-2013, 12:55 PM
The number of oz is just an estimate. It's set up to be a little more than you need then you reduce it to the correct level. You add that much oil then use a fork oil height tool to adjust the oil to the exact height in mm. You can guess but your front suspension will perform much better if you get it exact. See the service manual. There is a table and it does a great job of describing the procedure.
http://www.amazon.com/Motion-Pro-08-.../dp/B000GZPCYI
I'm at work right now or I'd give you the amounts.
rg_dave is offline
post #5 of 9 (permalink) Old 06-04-2013, 03:17 PM
NorCal's Avatar
the 2013 Manual states with damper valve:
10.7 oz
317 ML
4.92 IN
125 MM
NorCal is offline
post #6 of 9 (permalink) Old 06-04-2013, 05:48 PM Thread Starter
torqu's Avatar
Yeah. I just threw in 317 ml and called it good. Handles fine. Picked up a service manual today. Didnt measure like the manual stated. We'll see what happens.
torqu is offline
post #7 of 9 (permalink) Old 06-04-2013, 05:50 PM Thread Starter
torqu's Avatar
Dave, thanks for the link for the tool.
torqu is offline
post #8 of 9 (permalink) Old 06-04-2013, 07:36 PM
Worst case it would be a little stiff. If you put new lowers on you'll be really close just putting in that amount.
2013 Ultra
Pics here:
rg_dave is offline
post #9 of 9 (permalink) Old 06-04-2013, 10:26 PM Thread Starter
torqu's Avatar
Yes. I put new lowers and replaced all seal even though it only has 800 miles on it.
torqu is offline
