Fosgate media center vs Sony Marine - Page 2 - Road Glide Forums
post #11 of 28 (permalink) Old 11-27-2012, 02:13 PM
direwolf's Avatar
Cover
This is the one I use, got it from Sidecar Cycles. The first one I bought from Hawg-Wired but theres doesn't fit the Road Glide, sent it back as it was too big and only fit the batwings.
2008 FLTR & 2009 FLTRSE3
direwolf is online now
post #12 of 28 (permalink) Old 11-27-2012, 02:31 PM
Q-Hog's Avatar
I have the same one from sidecar cycles..
Q-Hog is offline
post #13 of 28 (permalink) Old 11-27-2012, 03:05 PM
h-donut's Avatar
pretty sure it fits
you may have to backspace mod your radio cradle or remove the bezel
I have a sony - but it works with alpine, etc
the billet bezel fell off my radio, somewhere between florida and louisiana
when I got home I installed the biketronics plastic face to clean up the gap.
splash cover fits much better without the bezel
since the bezel is a intricate part of the hawg wired system, maybe they don't recommend it
if I replace mine, I will cut it in half according to depth ways and do the backspace mod 3/8"
the further back the splash guard goes the better, had that fall off also,
luckily was going slow and grabbed it
my note would be the media center seems good, way overpriced, I am hoping spring will bring some options when the new electronics come out.
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #14 of 28 (permalink) Old 11-27-2012, 03:47 PM
direwolf's Avatar
I used the biketronics kit for the Sony so it's already been set back. When I talked to to Hawg-wired they agreed that it was not going to fit & send it back. The one from sidecar cycles is designed for the RG, they also make the cover that Hawg-Wired sells for the batwings. I'll put a picture up of the cover installed on it later.
post #15 of 28 (permalink) Old 11-27-2012, 04:57 PM
h-donut's Avatar
the one I bought was from sidecar, for road glide
look almost the same - so I thought it was
if that's the case, my bad, I apologize for spreading bad info
sidecar told be the difference was the offset, but it's been a while since I
had that conversation with them
update: okay I check my fitment, I definitely need to modify the backspacing since the selector button sticks up further on sony
I guess I never noticed
my hawg wired cradle is the older model HUA470
h-donut is offline
post #16 of 28 (permalink) Old 11-27-2012, 05:13 PM
Q-Hog's Avatar
The RG version should've came w/2 brackets to push back the radio cradle if you're going to use it w/the Hawg-Wired install kit.
Q-Hog is offline
post #17 of 28 (permalink) Old 11-27-2012, 07:09 PM
h-donut's Avatar
I have all the parts, this was just something that got pushed back
built all those brackets, then added lids and re-did my mains.
TO GET THE ROAD GLIDE RAINCOVER, you have to go directly to Sidecar Cycles
according to HawgWired... looked like the same part to me, wtf
anyone I told otherwise in passing, I was wrong about the spec
SORRY
better to have egg on your face than a face that looks like an egg.
fyi - the new daisy chain models from hawg wired are supposed to be soon in the coming
a reasonably priced kick ass stereo for the roadglide would be nice.
h-donut is offline
post #18 of 28 (permalink) Old 11-27-2012, 07:25 PM
direwolf's Avatar
Hey no apologies necessary, this isn't the HD Forumů
post #19 of 28 (permalink) Old 11-27-2012, 09:38 PM
h-donut's Avatar
cool
ya know, that rain cover actually works pretty darn well, even as all
odd fitting as mine is at the moment
now I have something to fix
h-donut is offline
post #20 of 28 (permalink) Old 11-27-2012, 10:16 PM
GlideShark's Avatar
The sidecar cycles cover only works with certain brackets? Hawg wired, Biketronics and that's it. Pricey but like the quick detach capability.
GlideShark is offline
