I have speakers mounted in the lower fairing, all wired up and for the life of me can't get the power to reach the battery. I have the amp placed on top of the OEM head unit and wiring down and centered, then under the tank's console. Yeah I followed the directions and just think
there is a trick to it. I know Hogtunes sells a side mount for the amp and maybe that will give me the cable length I need.
Thanks. I did just that, soldered, heat shrink wrapped and it's up and running. Hogtunes sounds pretty good. I can't believe the difference over stock tunes.....
I use to have a HT system but I upgraded to the J&M system but if I remember right you would need the mounting plate for the amp to get the wiring to reach.
You may also need the fairing lower speaker wiring harness for the speaker wiring to reach the fairing lower speakers.
This sounds like the same thing I was thinking earlier. I see the plate on their website and from the looks of it, it would give me more room on the power cables. Thanks.
Good to hear you got it up and running. Stocks sucks as you stated. I just upgraded mine last weekend and tested it for 175 miles today.
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
