Is my RF PBR 300 amp " clipping"????? - Page 2 - Road Glide Forums
post #11 of 14 (permalink) Old 11-18-2012, 06:51 PM Thread Starter
I'll give the ground a try and turn the gain down to where it was 5/6 and see if that cures the problem. The ground has been at the fairing mount for the entire time without a problem, then last week I fire the bike up for a ride and this problem rears its ugly head. Hope to have the time too tear into the fairing this week and check things out, if not I'll just keep the volume low until I get a chance. Thankyou for all the insight as I'm far from a stereo guru!!! Chris
HDFFR is offline
post #12 of 14 (permalink) Old 11-20-2012, 05:18 PM
Orange09Glide's Avatar
I also had a clipping issue. When I spoke to a buddy who runs an audio shop he stated the power wire and fuse were my issue. He recommeded I go with a 8 gauge power wire and 60 amp fuse(running two amps). Since switching out I have had no issues with clipping or the amps shutting down.
You might want to increase to a true 10 gauge power wire and run your ground back to your battery.
Chris
Orange09Glide is offline
post #13 of 14 (permalink) Old 11-21-2012, 08:02 AM Thread Starter
If I remember correctly I used a 10 ga. Supply for the power with a 30 amp fuse. I'll double check everything and increase the gauge of the ground wire while I'm at it. Thanks Chris
HDFFR is offline
post #14 of 14 (permalink) Old 12-04-2012, 01:46 AM
Arrow Clipping?
I'll be starting on my winter project as soon as I have all the pieces on hand.
PBR300X2 amp, and 1 set of Hertz 6.5" speakers in the fairing.
Has anyone else had sound quality issues grounding the amp on the frame "up front"? I'm undecided about where to ground it. Any tips or tricks running the power and ground wires under the tank of a RoadGlide? Thanx.
2whlr4life is offline
