Speaker question - Page 3 - Road Glide Forums
post #21 of 21 (permalink) Old 12-27-2012, 09:03 AM
h-donut's Avatar
look closely at the crossovers and remote options on the 2 channel amp
the 4 channel doesn't have that, to my ears and others it sounds better enough to mention it as a "want to have".
you can hookup multiple speakers to a single channel, and drive down the ohms to a 2ohm load, best performance v. dollar
not sure which cadence, some are listed as 4ohm, some listed as 3 ohm, which is 2ohm by application
if your total speaker pairing(s) provide a 2ohm load you can draw 170w-190w from that single channel, enough to drive both speakers.
have about 600-800w, use about 400-500w, that is your cleanest.
the head unit will do most of the work, agreed, but you should reinforce good crossover points, by duplicating them on the source, amp and speakers.
2010 FLTRX- r o a d g l i d e
h-donut is offline
