I'm having a 2 part problem with 2016 Road Glide with the 4.3 radio. When listening to Pandora on my IPhone 6 it connects fine through Bluetooth as long as my phone isn't plugged into the USB connection. As soon I plug it in, I can't get the music through my speakers. Also, the volume is too low, is there any way to change it?
the USB port that come with the bike will only allow you to listen to apple play or itune and will disconnect you from the Bluetooth music .
as that USB port is only used to read files
Well, that's stupid :smile: but I guess that explains that. I guess I need to make an alternate USB cable so my battery doesn't drain while listening to tunes. Is there a cure for the low volume?
I can bluetooth Pandora or plug into my USB port so I'm not sure why it's not working for you.
Turn on your bike.
Start up Pandora on your i-phone.
Plug your phone into your USB port.
If the music turns off after you had already turned it on and plugging in, re-open once again your i-phone while still plugged into your bikes USB port and hit the play button in pandora and it should play.
If you turn on Pandora & then plug it into your USB port it will not read until you press play on Pandora again.
Try that and report back.
Once again I can play Pandora on my i-phone & can use it by way of bluetooth or by plugging it into my bikes usb port as long as I press play again once system is up and running.
Swomack
I can run my music through a wired setup and get calls through Bluetooth. I can also play music through Bluetooth and charge with usb while still playing, and receive phone calls as well. The only difference is i am using spotify or apple music instead of pandora, but dont see why that would matter.
I first plug in phone to usb then connect through Bluetooth and play music. If i connect in opposite order it will try to play the music saved on the phone.
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
