I just installed a detachable tour pack kit on my '13 Road Glide Ultra and used the shorter antennas because I cannot remove the oem from the tour pack,(glued on tight). The reception is about 1/4 of what I got with the OEM ant. so I thought maybe I should eat it and just purchase a new oem antenna but when I removed the shorty ant from the bike it made no differance in the reception as if it was not connected at all, any Ideas would be much appreciated
According to the H-D spec sheet, the short antennas should have better reception for most distances and terrains. Sounds like you may have a loose connection at the radio.
Figured it out, Harley sends you an adapter [Male / female] that if used does not give you a connection between the antenna cable and the antenna, just removed it and the system works fine..not sure if its for another model or a different antenna mount..at least now when I screw on the antenna there is a very noticeable boost in the signal ...
I've tried several shorties and now running an internal antennae. Nothing works as well as the full size whip. The rest are all marginal at best.
Which is why I installed SiriusXM and have 35G of stored music to listen to ......
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
