glove box speakers - Road Glide Forums
post #1 of 6 (permalink) Old 06-27-2011, 11:04 AM Thread Starter
glove box speakers
has anyone put small speakers in the glove box lids.i wonder if they make something that small.saddle bag lids speaker, i cram to much shit in my saddlebags when i go somewhere.
Jerry W. is offline
post #2 of 6 (permalink) Old 06-27-2011, 11:23 AM
dirtbag's Avatar
As far as putting a coaxial speaker, like a 4", wouldnt be a good idea. The glovebox lid wouldnt be a good (sealed or sturdy) enclosure. On a RG at the Dragonfly Concepts booth, they did have a tweeter pod on each glovebox lid, firing towards the rider. It looked like ABS plastic pipe, cut at an angle, and molded into the glovebox lids. It looked nice, but I think anyone with some crafty skills could replicate 'em.
2010 FLTRX - THE RED DRAGON
KCCO - CHIVE ON!
dirtbag is offline
post #3 of 6 (permalink) Old 06-28-2011, 02:29 AM
BlackBetty11's Avatar
I also think Chainsaw made something like that.... Where is a good Chainsaw when you need him...
2011 FLTRU103Cali
2006 XL1200C
If only my job would understand that I have other things to do!!!
H.O.G. First International Free Chapter
Green Knights Chapter 27
BlackBetty11 is offline
post #4 of 6 (permalink) Old 05-03-2012, 09:25 PM
Glove box speakers
I just mounted my stock speakers in the glove Box lids. Took lids off tapped them up traced out size of hole using a bean can that was perfect size. Used jig saw with metal blade for smooth cut. I then put sound deadening material in the glove box. I can still put a far amount of stuff in the glove box. I mounted Polk mm651 6 1/2 in fairing with PBx-4 fosgate amp. Sounds great. I wired the 2 ohm speakers in series so they are being driven by the front channel of the amp because it is 4 ohm load. That leaves rear channel for speakers in bag lids which I am trying to do now.
Has anyone cut stock hd lids and put in speakers? Does that work or do I have to order aftermarket lids and paint?
Thanks for the help
Frank123 is offline
post #5 of 6 (permalink) Old 05-03-2012, 09:33 PM
L-Premo's Avatar
Hard ride audio has them as a system.
http://www.hardrideaudio.com/hra/cat...-products.aspx
I ride a Road Glide. Therefore I am!
'11 RGU Merlot Sunglo, Daymakers, Rinehart slip ons, stage 1, throttle pak, tour pak relocator, Madstad, Black +2 Sweepers, black ISO grips, split view mirrors, Transformer floorboards.
L-Premo is offline
post #6 of 6 (permalink) Old 05-04-2012, 04:47 PM
hdxbones's Avatar
Did it on my '07. 4" Polks-
Ridin' Roadglides before they were cool.......
hdxbones is offline
