dragos 107 stage 2 - Page 2 - Road Glide Forums
post #11 of 19 (permalink) Old 11-19-2012, 09:22 AM Thread Starter
bpt-bagger's Avatar
Thanks guys for clearing that up. Rob is sending me a new graph with the corrected scaling. Scott, ill pm you his info. Yes his down here on Bpt . If he okays me putting his info on here ill be sure to put it up. This forum has been a great source of info.
bpt-bagger is offline
post #12 of 19 (permalink) Old 11-20-2012, 07:05 AM
It looks very good Rob did a nice job on the tune. Just need to fix scale. But the numbers dont lie.
Wait until you get the our 54mm throttle body on there Thats port matched to your heads. You will see at leaset 4/7 more hp easy.
I am glade you are happy. Just remeber those heads are set up for a blower spec like we talked so when you are ready for a procharger we just need to swap out cams to my blower cams and easy 160/170 hp.....
Originally Posted by bpt-bagger View Post
Here its is dragos stage 2 kit dyno results
107.7 hp/118.5 ft-lbs
bike pulls like an animal. feels great
techno research direct link tuner
107 ci kit 10.6 compression (oem jugs Bored)
stage 2 heads
tman 625 cam
dragula 2 into 1
s&s push rods
gaterman lifters
rivera primo pro clutch
DragoBikeWorks is offline
post #13 of 19 (permalink) Old 11-20-2012, 09:29 AM
laxinharley's Avatar
Got your PM thanks for the info Henry..
laxinharley is offline
post #14 of 19 (permalink) Old 11-20-2012, 05:09 PM Thread Starter
bpt-bagger's Avatar
Thumbs up corrected scaling
Heres the correct scaling. Scott glad i could help.
post #15 of 19 (permalink) Old 01-04-2014, 04:34 PM
laserman's Avatar
Bpt looking forward to this build. Jugs & TB coming off this week and shipping to Frank. Local shop in Manchester will be doing the work. Dyno when done with Franks 611 cam will post numbers in a few weeks after he runs it on the Dyno.
laserman is offline
post #16 of 19 (permalink) Old 01-04-2014, 04:42 PM Thread Starter
bpt-bagger's Avatar
You're gonna love it! I'm also wanting to see what franks 611 cams does in comparison to the tman 625. Are you having head work done?
post #17 of 19 (permalink) Old 01-04-2014, 05:02 PM
ERod62's Avatar
Nice.. you sound pleased
Thinking on a 107 upgrade how is the local traffic riding?
Also have a great tuner near DOC, was offer 107 over the HD stage 4.
Congrats
ERod62 is offline
post #18 of 19 (permalink) Old 01-04-2014, 05:07 PM Thread Starter
bpt-bagger's Avatar
[QUOTE=ERod62;1421394]Nice.. you sound pleased
The ride ability is better then stock and with my dragula a lot less heat. I've zero issues the dragos parts and the dragula is hands down the best exhaust out. And I've owned them all (d&d thunder header bassani etc)
post #19 of 19 (permalink) Old 01-04-2014, 06:45 PM
laserman's Avatar
Yes, getting Diabolo 2 with upgraded jugs with bigger cooling fins for a little extra. Love the big low rpm torq he posted. Have the SCS pipe so expecting 2 or so less tq and HP. But jug upgrade should make up the difference to get close to 117hp and 124tq.
laserman is offline
