Rear fender filler and fender extension - Page 2 - Road Glide Forums
post #11 of 26 (permalink) Old 09-21-2012, 02:42 PM
Need some help with fitting the 2011 RG facsia on a 2009 RG
Besides the actual facsia are there other parts needed to make it fit?
The expert help of the forum members is very much appriciated,
Skitzogear is offline
post #12 of 26 (permalink) Old 09-21-2012, 03:22 PM
smitty901's Avatar
List floating a round I need to look mine up.
There is the mounting bracket has 3 studs on it few nut and bolt
Easy to do just make darn sure you got it right when go to mount it.
I just ordered it all again for my 2013.
smitty901 is offline
post #13 of 26 (permalink) Old 09-21-2012, 04:18 PM
I just do not want to drill my fender, is that something that needs to be done also.
post #14 of 26 (permalink) Old 09-21-2012, 04:49 PM
faststan's Avatar
The facia can be mounted with double sided tape (professional grade). Others have done it that way.
Easy to drill the fender though. Use masking tape on fender, locate the facia where you want it and mark the three holes on each side. Drill your marks, remove tape, insert the retainer strips thru fender and bolt on. I was apprehensive when I did mine but wanted the look, so get 'r done.....
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #15 of 26 (permalink) Old 11-08-2012, 03:08 PM
Flexin's Avatar
I want to do that extended look but I can't fine the part number referenced by smitty. I have a 2012 RGU. I see RWD has an expension for $291 unpainted and no mounting hardware. Any other options?
Flexin is offline
post #16 of 26 (permalink) Old 11-08-2012, 07:25 PM
HD_Shock's Avatar
It's all done with Harley parts ... here's some lists for you:
Anyone do the rear fascia mod to RGU?
Note the last part of facia number is the specific color matching. If your RGU is the same color as an available FLTRX, you could use that instead of a FLHX.
-phil
2011 FLTRX 103
HD_Shock is offline
post #17 of 26 (permalink) Old 11-08-2012, 08:19 PM
smitty901's Avatar
The 2011 was totaled in August . I went with black Fica on the new RED RGU I think it worked. Also did the spoiler lights in Black
post #18 of 26 (permalink) Old 11-08-2012, 08:50 PM
Tape it then ,awesome forum.
Sent from my iPhone using MO Free
post #19 of 26 (permalink) Old 11-08-2012, 09:01 PM
Flexin's Avatar
Smithy, sorry to hear about the other bike. The new one looks good with the contrast.
Do your still have the directions to do this? Seemed like there was a document floating around.
Flexin is offline
post #20 of 26 (permalink) Old 11-09-2012, 08:49 AM
wenchal's Avatar
You can't use use the HD filler strips unless you change out the saddlebag support bars. I put the Street Glide fascia on mine, I wanted the light...It came pre pained so was easy to put on.
Here is the post to mine, it has the parts in the string: Rear fascia RGU
wenchal is offline
