Outer Fairing screw hole stripped - Road Glide Forums
post #1 of 38 (permalink) Old 04-08-2013, 12:44 AM Thread Starter
motosig102's Avatar
Has anybody had the screw hole for the outer fairing strip out?
motosig102 is offline
post #2 of 38 (permalink) Old 04-08-2013, 12:52 AM
outlawjessejames's Avatar
YEP! Mine did this weekend. Subscribing since I'm lost here as well.
Outlaw
2012 Ultra Custom - Big Blue Pearl
outlawjessejames is offline
post #3 of 38 (permalink) Old 04-08-2013, 12:55 AM
LittleMoe's Avatar
Actually yea, there are a bunch of threads on the forum that explain in detail the many different fixes !!!! A search of the forum will definitely provide you with what you need !!!
'06 FLTRI/Gel seat/Rheinhart exhaust/PCIII USB/Wind Vest 16" sheild/Progressive Monotubes/WAAAY too much chrome Willie G chrome... wanna trade for blacked out parts?
LittleMoe is offline
post #4 of 38 (permalink) Old 04-08-2013, 01:42 AM Thread Starter
motosig102's Avatar
Ok so after searching and going through a thread I found the below thread that talks about a fix for this issue.
Fairing screws don't go it
post #5 of 38 (permalink) Old 04-08-2013, 02:13 AM
Xaran's Avatar
Fast fix is to slip a piece of zip tie into the hole and then thread the screw back into the hole. Long term fix is job weld into the hole nd then retap or put veg oil on the screw band push into the hole hen the job weld is soft. Also a little abs pipe glue into the hole will refill and then you can tap a new hole
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #6 of 38 (permalink) Old 04-08-2013, 09:01 AM
RedneckMedic66's Avatar
I took mine into the dealer and they called harley since i was apparently the first one to come in with this issue. Harley said to use a jb weld epoxy but the dealer couldnt find the specific one they wanted so harley sent me a replacement outer fairing.
GLIDE OR DIE!!
RedneckMedic66 is offline
post #7 of 38 (permalink) Old 04-08-2013, 09:08 AM
Screamin''s Avatar
Are you sh-tting me?? Man, what a deal!! My 2009 still under warranty and at least two of my faring threads are on their last legs. Hmmm...
2009 FLTR, Red Hot Sunglo.
Screamin' is offline
post #8 of 38 (permalink) Old 04-08-2013, 09:13 AM
Zog
Zog's Avatar
Wow they must have stripped them out, pretty sure that wouldn't work for those of us that removed the fairing ourselves.
2009 Black pearl 110ci,D&D exhaust, titanium gauges, Bright ass lights tailight, madstad windshiled, jac-knife highway pegs, progressive monotones, Ness Deep Cut Hot Legs etc..etc..etc...
Zog is offline
post #9 of 38 (permalink) Old 04-08-2013, 09:29 AM
JayKS's Avatar
I had one stripped, and my painter gave me a good tip. Put one or two drops of Gorilla Glue in the hole. Let it dry thoroughly (like overnight). Drive the screw in slowly and let it cut new threads. Worked great. (Do not put too much in the hole or the 'tower' will break apart when you try to drive the screw in.
I did this while I had the fairing off (inner was being painted). I even put a very small drop in the other holes. New each one is good and solid.
JayKS is offline
post #10 of 38 (permalink) Old 04-09-2013, 12:52 AM
I made it sound like it happened at my 1000 mile service. I know exactly when i did it though about 2 weeks after i got the bike doing the new speakers.
GLIDE OR DIE!!
