need help - Road Glide Forums
post #1 of 11 (permalink) Old 11-04-2012, 11:46 PM Thread Starter
need help
Guys I just picked up a 21 front wheel off a 2008 street glide will it just bolt up to my 2005 road glide .Do have to change the bearing and that pole inside the wheel please help
badboyindc is offline
post #2 of 11 (permalink) Old 11-05-2012, 08:00 AM
mocotom's Avatar
The 2008 SG had 25mm bearings from the factory, your 05 will be 1" bearings. You will need to change bearings and spacer to 1" or buy a 25mm axle. Either way will work if this is an aftermarket wheel, which being 21" I assume it is.
2005 RG 98cu in
mocotom is offline
post #3 of 11 (permalink) Old 11-05-2012, 08:05 AM Thread Starter
Help
YES IT IS A CUSTOM 21' CVO WHEEL GUESS i WILL HAVE THE SHOP CHANGE THE BEARING TODAY FOR ME THANKS FOR YOUR HELP
post #4 of 11 (permalink) Old 11-05-2012, 08:24 AM
mocotom's Avatar
When you say "CVO" wheel, is it a Harley wheel from their catalog? The reason I'm asking is some of the newer wheels from Harley will not accept 1" bearings. The outside diameter is the same on both 25mm and 1" bearings, but the width is different. Most late model wheels from Harley do not have bearing pockets in the wheel that are deep enough to install 1". Just trying to make you aware of possible problem.
2005 RG 98cu in
mocotom is offline
post #5 of 11 (permalink) Old 11-05-2012, 08:41 AM Thread Starter
No its a pm cvo wheel
post #6 of 11 (permalink) Old 11-05-2012, 09:24 AM
Wheel & Customer Service Expert
CM_Jeff's Avatar
If it is a Performance Machine wheel you will need to change the entire hub set.
Thank you
Scott Shouse
888-899-6686
Best Prices / Best Customer Service
CM_Jeff is offline
post #7 of 11 (permalink) Old 11-06-2012, 10:56 AM
www.hogpro.com
HogPro's Avatar
Pm hubs are proprietary as well so you will need to get a PM hub.
HogPro is offline
post #8 of 11 (permalink) Old 11-06-2012, 11:06 AM Thread Starter
Hogpro you are right i had to change it all the hub the bearings and rotors
wow I think I should have got a new wheel instead of a used one but it on bike now and look good I want to change the spacer to chrome can i do that Hogpro
post #9 of 11 (permalink) Old 11-06-2012, 02:29 PM
www.hogpro.com
HogPro's Avatar
Yes you can change them to chrome. PM makes a nice looking spacer although they are pricey. harley also makes a nice tapered front spacer that you can get at the dealer.
HogPro is offline
post #10 of 11 (permalink) Old 11-06-2012, 02:42 PM
CM_Jeff's Avatar
You should have recieved axle spacers when you purchased your new hub. I would check with the dealer that purchased the hub for you.
Scott Shouse
888-899-6686
CM_Jeff is offline
