Need Help fatter tire on older shark - Road Glide Forums
post #1 of 6 (permalink) Old 11-05-2012, 09:28 AM Thread Starter
I have a 2000 glide, I purchased a Michellin Commander 150-80-16 for the rear problem the saddle bag fender support bracket is not wide enough.
Anyone know the fix for this problem, I was looking at the parts file for a 2007the bracket is shaped different but I don't know if it will fit.
The fender is plenty wide enough however that darn bracket is giveing me fits any help or suggestions will be greatly appreciated
2000 FLTR, Mikuni HSR42, 2007 Swingarm, Andrews 26 cams, hydraulic cam chain tensioners, high output oil pump, 12" Monkey bars, HID headlights, custom dynamics LED's turn signals front and rear, tour pack LED's, LED brake light, Custom Dynamic brake turn module, 2007 turn signals, Cee Baily 26in windshield, Rockford Fosgate amp, JL speakers, Alpine head unit, detach king tour pack, custom painted by aggressive designs.
Sealdoggy is offline
post #2 of 6 (permalink) Old 11-05-2012, 10:20 AM
I believe that your model year FLTR comes with a 130 tire and the tire you just got is too wide to fit. You would be better off just staying with the stock tire size because along with the bracket problem you may have a belt clearance problem as well. MY 08 has the 140 tire size stock and most 150 tires are too wide for my bike because of the belt clearance so I just stick with the stock size.
post #3 of 6 (permalink) Old 11-05-2012, 11:20 AM Thread Starter
I changed out the pully and belt as well as the swingarm, I put a 2007 swingarm in and a 11/8 pully and belt.
Just having a problem clearing the saddle bag support bracket, anyone done this mod care to share your thoughts on changing or modifying the width of the bracket.
post #4 of 6 (permalink) Old 11-06-2012, 12:54 AM
A pic would help, I did the late swingarm upgrade on my 89 with a 1" belt and have a 140 tire with a ton of room around the tire. I cant picture where you clearance problem is.
1989 Tour Glide "Ester"
Desertkowboy is offline
post #5 of 6 (permalink) Old 11-08-2012, 05:27 PM
www.hogpro.com
HogPro's Avatar
2007 baggers use a 66x1" pulley. That might help, but you will need to change the belt as well.
HogPro is offline
post #6 of 6 (permalink) Old 11-11-2012, 08:20 PM
I have that exact tire on the back of my 07 , so what ever the diference is it will fit the 07. Can't go any bigger though for sure.
As mentioned earlier I think the belt is narrower than the previous models.
It is a tight fit but I have 8000 miles on mine with no issues at all.
Tom
Lord Help me to be the Man my Dog thinks I am!
TearlessTom is offline
