wheel help - Page 2 - Road Glide Forums
post #11 of 16 (permalink) Old 11-08-2012, 01:39 PM Thread Starter
I dont think the fender is the problem going to pull rotors to see if that is the problem
badboyindc is offline
post #12 of 16 (permalink) Old 11-08-2012, 01:45 PM
staush's Avatar
I wouldn't pull the rotors just yet. Pull off the calipers first see if that helps. If it does then check clearances as you slide them back on. If they are tight then look at wheel spacers.
staush is offline
post #13 of 16 (permalink) Old 11-08-2012, 02:24 PM Thread Starter
thanks that just what i will do when i get home
post #14 of 16 (permalink) Old 11-09-2012, 07:20 AM Thread Starter
Want to thank all the guys on this forum for your help the wheel spin smooth now took it apart change the spacers and it was fine thanks guys so much.
post #15 of 16 (permalink) Old 11-09-2012, 07:21 AM Thread Starter
post #16 of 16 (permalink) Old 11-12-2013, 06:31 PM
mjsdouble's Avatar
I could be wrong .. I believe you should put on new pads if you replace your rotors.
2012 RGC aka Black Sassy, Vivid Blk, 12" Drk Wind Splitter, V&H Chrome Pro Pipe 2-1, SE AC, PCV, WO612 Outlawz, CM 21/17 Raiders, Monotubes -2 and 444's 11.5". Willie G Theme
mjsdouble is offline
