wheel help - Road Glide Forums
post #1 of 16 (permalink) Old 11-07-2012, 10:34 PM Thread Starter
wheel help
Put on a 21" wheel and its on the stand it not moving free it like something is holding it back is it to tight or something bearing are be and use my stock spacers
badboyindc is offline
post #2 of 16 (permalink) Old 11-08-2012, 01:13 AM
I dont have a 21" wheel but from what i understand is that you need to make the rear fender mounting holes larger so the rear of the fender can pick up alil and give you the clearance you need. Or at least loosen the fender bolts and make sure that is the problem before you drill them out
post #3 of 16 (permalink) Old 11-08-2012, 01:19 AM
Stray Mutt's Avatar
Could be a dumb question, but did you confirm it's not rubbing the fender? There's about a 1/4 of slop in the struts that you need to max out to ensure clearance.
Stray Mutt is offline
post #4 of 16 (permalink) Old 11-08-2012, 07:34 AM
Peppa1's Avatar
Did you put the spacers back just like they came off ?
2012 Road Glide Chrome Yeller - V & H Monster Rounds, SE Race Tuner, SE Heavy Breather, 10" Windvest, Sinister Industries Hot Rod Drag Bars, 21" Renegade Yukon Front Wheel
Peppa1 is offline
post #5 of 16 (permalink) Old 11-08-2012, 11:28 AM
02heritage's Avatar
Also make sure the spacers are ON the correct side. I know that on my 07 that one side is a little longer than the other. Although you should have seen a problem when putting the calibers back on.
2012 Maple CVO
02heritage is offline
post #6 of 16 (permalink) Old 11-08-2012, 11:43 AM
laxinharley's Avatar
Theres supposed to be a little resistance there. Don't know what year but make sure your abs is hooked up properly within the tabs if you have it. Also like Rlaf75 said make sure your reem out your back holes on the fender, so you can tilt it up a bit.
laxinharley is offline
post #7 of 16 (permalink) Old 11-08-2012, 12:07 PM
Wheel & Customer Service Expert
CM_Jeff's Avatar
Not sure what bike the OP has but some of the Screamin Eagle models require a fender bracket to raise the fender.
Scott Shouse
888-899-6686
Best Prices / Best Customer Service
CM_Jeff is offline
post #8 of 16 (permalink) Old 11-08-2012, 12:35 PM
www.hogpro.com
HogPro's Avatar
What year is your bike? Did you put new rotors and pads on too?
HogPro is offline
post #9 of 16 (permalink) Old 11-08-2012, 02:36 PM Thread Starter
I added new rotors but not new pads you think the pads are to thick or some thing going to pull the rotors off and see if they spin free
post #10 of 16 (permalink) Old 11-08-2012, 02:37 PM Thread Starter
my road glide is a 2005
