non-abs wheel on abs bike - Road Glide Forums
post #1 of 2 (permalink) Old 11-24-2012, 07:52 PM Thread Starter
Local guy has a 21 inch front wheel from southern motorcycle works. He says it was on his 2009 street glide and that the wheel was for a non ABS bike. My 12 road glide is ABS and I'm interested in buying this wheel. Just curious what I need to do to run this wheel. Will my bearing on my factory wheel swap over?
Thanks
Wesley
2012 Road Glide Custom
Cut, raked and stretched rolling on a 26!
W_D_R is offline
post #2 of 2 (permalink) Old 11-24-2012, 08:54 PM
CHAINSAW's Avatar
You need a different bearing,.. that is all. Check with your dealer on the bearing part number,.. but the wheels are the same, just different bearings.
Such is the rule of honor.
CHAINSAW is offline
