Changing wheel diameter & ABS - Road Glide Forums
post #1 of 7 (permalink) Old 11-27-2012, 07:15 AM Thread Starter
Wiggles's Avatar
If the wheel diameter is changed does it cause problems with the ABS?
For instance if a Road Glide Ultra with ABS and a 17" front wheel is changed to an 18" front wheel....
If it does matter, is there a setting in the ECM or ABS that can be changed to correct for the wheel diameter change?
Thanks!
Wiggles is offline
post #2 of 7 (permalink) Old 11-27-2012, 07:30 AM
mocotom's Avatar
It will have no effect on the ABS.
2005 RG 98cu in
mocotom is offline
post #3 of 7 (permalink) Old 11-27-2012, 08:37 AM
Rowdy's Avatar
Lot's of folks have changed out there wheels with no ABS issues at all.
Rowdy
Rowdy is offline
post #4 of 7 (permalink) Old 11-27-2012, 09:02 AM
laxinharley's Avatar
Mocotom and Rowdy are both correct. You will be fine. I went to a 21" from stock and ABS is fine.
laxinharley is offline
post #5 of 7 (permalink) Old 11-27-2012, 10:17 AM
www.hogpro.com
HogPro's Avatar
The abs works off the wheel bearing in the left side of the front wheel(sitting on the bike) and the abs pick up which functions as the left side front wheel axle spacer only which talks to the computer. The wheel size does not affect the abs.
HogPro is offline
post #6 of 7 (permalink) Old 11-27-2012, 06:57 PM Thread Starter
Wiggles's Avatar
Abs
Thanks!
I didn't know if the ABS calculates the wheel RPM and tracks it to prevent a "lock up" or if it just activates when there is a zero RPM situation on a wheel when the other one is still spinning.
If it was working off of the wheel RPM I was worried about a taller wheel having a longer rolling distance per rotation & throwing off the calculations.
If that were the case the ABS would not work correctly but the ABS light would not show a warning.... But the ABS would not work correctly in a panic situation.
Jim
Wiggles is offline
post #7 of 7 (permalink) Old 11-27-2012, 08:06 PM
skratch's Avatar
Thanks!
in your example, if you are talking stock 18'' vs stock 17'', then is almost no difference in overall height between the 2 because of the different profile of the tires. so even if it did make a difference, in this case it wouldn't make a difference
in the stock harley sizes, there is no discernable difference between the 16'', 17'', 18'' or 19''. just fyi
skratch is offline
