I already have the SE 103 build in my bike with the flat top pistons and the SE255 cams. At this time the bike has the stock heads and I am thinking about upgrading the heads, so should I just have my heads reworked or should I buy the heads already done? I am looking into the HD SE Pro CNC ported factory cylinder heads with valve upgrade or the SE Pro Kompressor cylinder heads. Also would the 255 be a good cam to keep or should I go with a different cam? I do like the low end torque that the bike has with the SE255's
I've done 2 of my HD's so far. I sent in my stock head to Branch and the second one to Branch/Okeffe to be reworked. On my RK I had them do what is called a Touring head mod. I picked up 9 extra HP plus additional torque. I just have baby cams in it (490 lift) but all kinds of low end TQ. I would think your 255's would be just fine. You can also change your head gasket to a .030 Cometic for some additional bump with those cams.
The stock heads and compression are well suited to the 103 with the SE255 cams and the cost to do the head work would really beg for more cam to realize any real results and that would be in the form of added HP and torque at higher rpms. If done properly the low end manors will remain robust.
IMO......255 cams are ill suited for anything over and above cleaned up stock heads. They make power by upping the compression with cam grind method (early intake close and very little valve overlap.) Worthwhile in their own right but not suited for real performance. Head work like you are talking about is only one part in a recipe for a engine build. Have you any experience with a 110 hp 120ft lb tq engine for instance? I think you will find after expending much time, cash and headache, if you do not have a clear idea of where you are heading, you could end up too close to where you are now to justify the cost. My 103" 255 build makes about 90 hp and over 105 tq. In order to really feel a decided difference you will need to go quite a bit larger in displacement to satisfy a need for "more". In a bagger, especially one that runs around two up and covers land with numerous elevation changes and fuel availabilities, one would be best to err on the side of conservative. However, if you ride what is technically a bagger but is in reality some thing that is made to dash about madly, well then, this changes everything. Spec the machine honestly for the task at hand, realizing that nothing covers everything. Oh yes..and while we are on the subject of 103" and 255's.......DO NOT let anyone tell you they don't need some sort of compression release. You will (as I have) rue the decision to omit them. FWIW.
A local guy here did a combo at dealer.
103 ultra
SE compression heads
259E
V&H dual cross over with montser round mufflers
Dealer tuned it in at 108 hp 108 tq.
SEPRO tuner.
He was not happy and the bike will be here in 2 weeks for us to give it more power..
I will take of the heads rework them
And we are going to add a tman 600sm cam.
Port match throttle body. clean her up.
And retune it.
I am not going with the Kompressor heads. I decided on a different set of heads that have bigger intake (just over 2 inch) and bigger exhaust valves, I don't have the exact dimensions on the valve sizes right now. The heads are CNC and are ported and I am having them polished as well and they will have ACR's installed too, right at this time I am sticking with the SE 255 cam that I have in the bike but I am having adjustable push rods installed so if I want to change cams latter on it will be easier. I am also having the high compression pistons installed, with this combination I may be able to go to a different cam down the road but this will be OK until the engine is broke in.
not sure who suggested this,or if you came up with it on your own,buts its not going to work very well (S&S .570`s would like this build)the 255`s are very low end end torque cams & the bigger valves will kill any low end power (mid-high RPM like big valves)the 255`s wont like tons of compression either
Assuming the new heads have the same combustion chamber volume. The early intake close of the 255 cam, will already have your cranking compression and corrected compression in the higher range. Adding even more compression via pistons is going to exaggerate that even more. Hopefully they give it a really good tune, so it doesn't ping. You'll definitely be needing the ACR's. if the new heads have more chamber volume, and the new pistons are there to make up the difference, then forget what I said!
fuelmotousa did mine on the 10 FLHTK ~ so far 40k later not a hiccup ~ my 103 dyno'd at 110/114 without a tune ~ utilizing the auto tune and accepting the trims.... These were the type B heads ~ I sent Jamie a set of 110 head for the CVO ~ can't wait to get them back and installed ~
If I am sticking with HD parts which SE cam would work the best with this build. The compression on the bike should only be 10:5 to 1 so if the 255's won't work well now would be the time to change the cams.
IMO, you should select the cam, which has the characteristics that will compliment your riding habits, first. Do you want the power band favovoring the low, mid, or high rpm's? Then, choose a head/piston/tune combo that will compliment the cam.
BTW, I'm no expert by any stretch of the imagination. Just have received a lot of great advice, that's later proven to be correct, from experienced builders who post on here, and elsewhere. Has spared me much aggravation, and even saved me some cash.
I like the low end and mid-range torque that the SE 255 produce but with the build I may be able to go with a mid-range torque cam. I am not a high speed rider so I would like a cam that turns on around 2000 RPM's and give the bike plenty of power and torque thru the entire RPM range.
Seems like folks have gotten broad torque curves with the 254E, but if you prefer to favor the mid to low, perhaps the 204? Gotta be a few guys on here that have put these to use, and could let you know what they think about them. Maybe talk to whomever is going to tune the bike, and see what they think, or are partial to?
So many damn choices, it can be frustrating at times.
Maybe I missed something, but I don't understand why you went with high comp. pistons if your riding preference is low and mid range rpm. High compression requires greater overlap cam timing in order to "bleed" cylinder pressures down at lower rpm so you can still run pump grade gas. Most of these type cams will come with high lift and increased valve noise. My question is why build a hotter running, noisier motor if your goal is more torque and longevity.
I am getting the top end freshen up anyways so that is when I said I would get heads for the bike and I decided to go with the high compression pistons on the advice of the builder. The builder is going with .10 over on the pistons and he is polishing the heads as well. All the parts are ordered at this time except the cams so at this time I am going to continue on with this build, I may be able to stick with my cast flat top pistons but that may depend if he bored the jugs the .10 over yet and the shape my piston are in. If I change anything I will have to wait until Tuesday because the shop is closed on Monday.
no offence to anyone,but if you told the builder what your wanting & he came up with this set up,ide be looking for another builder.depending on what compression your going with & having to stick with HD parts,the 211,251 or 257 are the only cams ide suggest with heads having valves that big,and youde be looking at a decent mid - high RPM build.my advice if your wanting to keep it a low RPM,torquey build is to use mildly ported heads with a 1.900 MAX intake & stock size ex,keep the higher compression and go with a set of WOODS 555 or 777 cams
Same thing I eluded to in post #3
There are Street Ported heads then there are those that are called that and offer the meat and potatoes to get the job done, have bronze guides, airflow and don't break the bank. 1.9 intake valve is a natural. Cam most often used here these days is a TR555TQ for that build. All the low end of the SE255, ping potential diminished (added squish grooves), and still pulls strong to 5,800 an torque is still over 100 from 2200-5200.
When I had my engine bored out to a 103, I described what I was looking for as follows;
Something to flatten the hills, shorten the passing lanes, and something to cruise the highways (2 and 4 lane, straight and twisty).
Here is what the builder did. Called Bob Woods at Tom Woods... (where is Tom if Bob does all the work?) and relayed the info. Bob recommended his TW-7H Cam for my riding. There was some hemming and hawing between this one and the 777, but being a Highway Cruiser, that came down on the side of the TW-7H, as per Bob (something about the 777 being more of a Bar Hopper?). What I ended up with was the Woods Cam and Lifters, 10.5 to 1 flat top cast pistons (nothing expensive, not even sure what brand they are), and an increase from 96 to 103 Cubic Inches. I already had the Stage 1 Intake, and I added Drago's Dragula to the mix. No head work was recommended. I asked about it, and was told it would add HP and TQ, but it was nothing that would substantially add to my riding.
That was over 15,000 miles ago. Been cruisin' happy ever since.
A head you might want to look at if your staying with MOCO part and want to keep a good strong bottom end that will still carry out a little ways is the CNC stock head. They are using the 1.875 intake valve and as other have said it will sure save the low end. Couple guy around here are running them and are very happy and the dealer is still covering the bike on the extended warranty
If in fact it were here, a good recipie would be a Wood 6, and a set of our Stage III Touring Heads(1.940" intakes/1.630" exhausts).
Smooth, cool-running combo.
It'll strike torque similar to the 255 "school-bus" cams, but will carry much farther into the rpm band.
Scott
IronMark, i just went through this last week with my 2013 roadglide ultra. every shop it seemed wanted me to use the 255's. i wanted the 204's, so the shop i usually deal with worked with me on a recipe, and it worked out great for me. here's what we used, and the results.
factory c&c ported s.e. heads which also come bored for compression releases
204 cams with the good inner cam bearings
forged rocker support
hi lift rockers, i believe they're 1.7+ ratio
removed the casting flange in the throat of the stock throttle body
s.e. pro super tuner
stock cast pistons
adjustable pushrods
vance & hines pro pipe
torque on the dyno is 114.81
hp is 104
i'll be welding up the 1" hole in the baffle of the pro pipe they used for the sniffer during the tune. that should lose about 2 hp, but gain about 4+ ft lbs of torque.
what's interesting is the area under the curves of the tq and hp lines on the dyno sheet. the cams with the hi ratio rockers pull just about as strong as the 255's down low, but midrange is incredible, and the torque doesn't fall off drastically like 255's do at about 4k/4500 rpm's. they pull all the way through and beyond 5500. i believe the rockers really wake up the 204's
this recipe was exactly what i was after and i'm very happy with the build. there's more power everywhere, and fits my riding style perfectly.
whack the throttle just off idle, and it's exhillirating, pulls surprisingly strong throughout the rev range till i hit the rev limiter at 6200. i'm not a builder, but i know what results i want, and i hope this info helps.
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
