I came across something earlier this week that seems like such a good idea that it'll surely catch on. I have one on the way and will report back if anybody here is interested.
The skinny of it... Dobeck Performance has come up with an instrument to help the avarage guy set up their motorcycle to run the way that it should. From the description the user removes the cover and then drills a small hole in the exhaust headpipe and installs a riv nut of sorts with a puller and with parts supplied. A sensor is then screwed into this driving a display that clips to the handlebars or similar which is powered by a plug that can go into a cigarette lighter in the fairing of our bikes. Then while riding the fuel air mixture can be measured giving the ability to tune the bike and get it spot on.
Once finished a small bolt with a washer is screwed into the rivnut to seal the hole.
Okay, here is the best part. The rental is $20 per week beginning when the tuner arrives, and ending when the box is postmarked for return. It should be here tomorrow... Excuse me a moment... I'm back after taking a moment to moon walk across the room and then do cartwheels all the way back. Can't wait to play with this thing.
