Ok on my new bike getting it into neutral is a bitch. Is there something that can be done? All the other bikes I have owned might have been tricky but not like this.
+1 the shift pattern is so tight with the 6sp trans once you get it broke in and use a heavy gear lube adjust the clutch it will be ok easy to jump from first to 2nd
You guys nailed it. Mine was awful trying to get into neutral at first. The more miles I put on the easier it got. I just went over 1000 miles this weekend and have noticed it's not a problem anymore. Got my 1K service set for later this week.
In addition to what's been stated - all good advice - if the primary was over-filled it will be hard to get into neutral when the motor is running. From dry I believe it should have 45 ounces, 38 when doing a change.
While you're at it, do a bit of searching for clutch adjustment. I'm not sure how they do it but somehow the factory manages to screw up the clutch adjustment, which is critical to finding neutral.
Try this, with the bike idling in 1st gear, try rolling the bike backwards on level ground. You should be able to roll it backwards in 1st gear the same as in neutral, if you can't your clutch adjustment is off.
mine is ready for a clutch adjustment, I used that same rollback test to verify
you don't have to spend huge money to improve your shifter
Related Threads
Road Glide
1.4M posts
49.3K members
Since 2009
