This is kind of a long answer.
Add slightly more than 10.7oz or 317ml.
Add oil a little at a time and pump fork tubes as you go.
Use the fork spring to push damper valve to bottom of tube.
Remove fork spring slowly.
Pump a few more times.
Bottom the tube.
Set fork oil tool to 125mm
Use fork oil level tool to set the oil to the correct height.
Assemble
I've done it both ways lots of times. If the forks are off the bike because you are adding chrome or black lower tubes then do it the way I said. If you are just changing the oil you might do the measure what you take out. I do seals etc... when I change the oil. A half cm of height on the oil will make a big difference in ride. Too much = too stiff. Too little = too soft. You can still use the tool to add or remove oil to adjust the ride while the forks are on the bike.
well, that would depend also on what type of oil you put back in. some folks swear by the se heavy, while others think that it is way too stiff.... some even mix the heavy and the type e (stock) for a 'custom' blend.
and then too, it could be both, too much and too heavy
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
