Battery problems - Road Glide Forums
Old 04-13-2012, 12:36 PM
RoadGlide0611 RoadGlide0611 is offline
Default Battery problems
I put in a brand new battery last year. Seem to be strong all year with no problems. This winter, I had a lot of winter projects on the bike, and must have listened to the radio a little longer than I should have without the tender being on it. The battery was so low it wouldn't turn over the bike. So, I charged it up and while riding the volt meter pegs at around 1400 (2 o'clock). But it seems to turn over slower than it used to. So, I'm leaving it in the garage without the tender on it for a day or two to see if the battery goes down to the point where it won't turn over. Hopefully it's just a bad battery. It's got a 24 month warranty. Anyone else have any issues like this?
Old 04-13-2012, 01:17 PM
DED HD's Avatar
DED HD DED HD is offline
What mods did you do this winter that potentially could be causing the bike to not turn over as easy? I have similar issue, but last night after changing the map on my PCV, the bike seems to turn over easier, so something tells me it could be a tuning issue.
'10 Red Custom:
check out my build thread for pix and mods http://www.roadglide.org/showthread....t=GR8FLH+Build
Old 04-13-2012, 01:43 PM
I did a lot of things to the bike. New bars and heat demons, new heavy duty clutch diaphragm, new amp. And other things like seat, and shocks. But all the engine work was done on the bike the year before. Bike runs great. I was also wondering if the amp was pulling volts while the bike was not on? I wouldn't think so, but hey never know.
Old 04-13-2012, 01:57 PM
DED HD's Avatar
If your amps not grounded properly it certainly would.
'10 Red Custom:
Old 04-13-2012, 05:12 PM
BLKNCr6's Avatar
BLKNCr6 BLKNCr6 is offline
Moderator
Is there a chance your tuner turned off the ACR?
My SEPST did it one time...
...and I used to think my Sportster was heavy...
A Harley will get you through times of no sex, better than sex will get through times of no Harley.
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
SE Pro Super Tuner to make the above play nice together.
Old 04-13-2012, 08:43 PM
Maybe a dumb question but what is acr? And how would I know if that happened and how to turn it back on?
Old 04-13-2012, 09:12 PM
JJSW1283's Avatar
JJSW1283 JJSW1283 is offline
Auto compression release
