107 results in disappointment - for now - Page 5 - Road Glide Forums
Old 07-21-2012, 08:55 AM
harleson's Avatar
harleson harleson is offline
Our shop in Lubbock are getting 112 tq and 118 HP with 103 stage 4 and the 259e cams. But Drago FM and Hillside all know more than I ever will.
Tim Harleson
Lubbock Texas
1985 FXRS-SP 80ci Signal Red
2011 FLTRU 113ci Merlot Sunglo
2004 FLHT - RIP January 2004 - August 2008
Old 07-30-2012, 08:08 AM
GroundPounder GroundPounder is offline
Originally Posted by fuelmoto View Post
without having done the build or tune it is difficult to speculate. However note our fm "hellraiser" builds are essentially blueprinted builds we do in house with the greatest attention to detail. While your mix of parts may be the same the difference is very likely in the details. Did they check squish, deck height, etc.. And correct if necessary when they were doing the build? What oil and fuel did they use? How was the motor broke in? And on and on. I would strongly suggest checking the tune as it is especially critical with a high output build like this, and if necessary have the engine builder and tuner contact us and we are here to help. Also note the 58mm tb is likely not doing you any favors for left side power and torque but it should still work. The fact that there is not a afr graph on your dyno chart and it is also detonating would point straight to the tune, if it is pinging at all at wot during the dyno runs the knock retard is pulling timing=and performance. If you need any help you are welcome to contact us at 877-729-4754 and if you ant to bring it over i know we can straighten it out for you no question about it.
dang, now thats customer service.......
Old 08-22-2012, 07:52 PM
wolfsglide wolfsglide is offline
I had a 107 S&S side winder kit with a 58 mm TB installed in my 07 softtail, and that S.O.B would flat out run. In fact I'm thinking about converting my 01 RG to a 107 S&S. Your problem might be the wrong size injectors in the 58 mm TB.
Old 08-22-2012, 11:16 PM
OuchMMC's Avatar
OuchMMC OuchMMC is offline
how much did you pay for this upgrade bro? the numbers dont sound right.
i put about 6k in a 95''. and am pushing 106 hp and 113 tq.
2011 RGC STOLEN, 2012 RGC CUTOFF BY A FORD FIESTA!! 2011 RGC used with lots of accessorys! STAGE 4 103! CATCH ME!
