Question on Speakers, Rokkers or ???? - Road Glide Forums
Old 11-02-2012, 08:47 PM
danyg2006 danyg2006 is offline
Default Question on Speakers, Rokkers or ????
So ive had my RoadGlide two weeks now and I am already to upgrade my dull stock speakers. What I do know is i am going with two RF PBR 300X2 amps ( one for front speakers and one for some saddlebag speakers. My question is should i go with the Rokker 7 1/4 in the bags and fairing at a whopping $600 for two pairs or go with some kickers, JL, CDT etc in the 100-150 per pair speakers. I want big sound, no distortion and to be able to hear a little bass at cruising speeds. Just not 100% sold on paying premium for the Rokkers. I also plan on adding the two extra fairing speakers near the glove boxes to one of the amps later on. Thanks ahead for your input!
Old 11-03-2012, 06:45 PM
Neano62's Avatar
Neano62 Neano62 is offline
Send a message via Yahoo to Neano62
Default You GET what You pay for!
Do urself a favor and call Frank @ 815-765-1790 ,... after you call Rob @ 510-894-2999.
Get ur Specs and info down , b/4 you call Rob man, cause he knows his shit, and WILL NOT try to sell you one thing! But I guarentee you this, he will convince you!
Then call Frank and order ur Goods!
Hawg-Wired Rules!
Old 11-04-2012, 03:34 AM
Peewee's Avatar
Peewee Peewee is offline
Gots to agree w/ Neano. I'm ditching my J&M Rokkers for Hawg Wired. Got a few things before that get done, but then the swap is happening!
"Know Thyself"
Old 11-04-2012, 06:10 AM
cypress's Avatar
cypress cypress is offline
If you are going to add a third pair of speakers later I think one of those amps needs to be a PBR300x4.
2012 FLTRU - Custom Candy Orange - Dynojet PowerVision - V&H Monster Rounds - FuelMoto Pro Billet A/C
Old 11-04-2012, 06:25 AM
Garemlin's Avatar
Garemlin Garemlin is offline
Look into Biketronics Titan II's. I am running them with no amp on a Sony h/u and get pretty good sound at higher volumes with no distortion. Should be even better with an amp. One great feature about Biketronics is they have a lifetime warranty. Unheard of with any other company.
Biketronics
Old 12-03-2012, 06:36 PM
Ok, after a lot of research and though, I ended up installing the RF300x4. I replaced the stick speakers with Polk MM651 components and added two Polk DX5.25 slim design in the lower part of the fairing behind the glovebox. Man does this set up sound amazing! Gain adjust is not even Half way up and at 4-5 bars of volume it is as loud as I can stand it sitting in the garage. What is surprising is that I have a full sound with even a little bass.
Old 12-03-2012, 06:38 PM
ImageUploadedByMO Free1354581445.741737.jpg[ATTACH]17225[/ATTACH
Couple pics of installation
File Type: jpg ImageUploadedByMO Free1354581464.422235.jpg (30.6 KB, 100 views)
Old 12-03-2012, 06:39 PM
Two more picsImageUploadedByMO Free1354581562.757576.jpgImageUploadedByMO Free1354581581.320766.jpg
Old 12-04-2012, 01:25 PM
glide1's Avatar
glide1 glide1 is offline
Do you have that amp running off the stock radio? If so what wire harness did you use for installation?
Old 12-04-2012, 06:25 PM
Yes i took both speaker channels off the radio and wired them to the amps supplied harness ( cutting rca ends off and Sodering) Then i switched the amp input to 2 channel so that it takes two channel from the stock head unit and converts it to four channel out put.
