H /D Heated grips - Road Glide Forums
Old 11-05-2012, 07:24 PM
dbhwt dbhwt is offline
Default H /D Heated grips
Who has em on...who likes em and have they held up for you ?
Old 11-05-2012, 09:07 PM
Heated gloves are better then the heated grips IMO. Heated grips heat the palms of your hand but heated gloves heat the back of your hand where the cold wind actually hit your hand.
Old 11-05-2012, 09:09 PM
billy t billy t is offline
I just picked up a set. Got the same ones that come on the batwing ultra limited stock. That leads me to believe that they are going to last awhile. My brother has them & loves'em. Will be installing them in two weeks.
12 RGU Ember Red Sunglow
Heated Hammock seat, CVO bars
Decat, heated grips
Old 11-05-2012, 09:10 PM
eme56's Avatar
eme56 eme56 is offline
I put the Rubber and Chrome heated grips on when I put the Heritage +2 bar on. So far, I like them. They have been on twice and worked well. I did buy new gloves after the first use. Lee Parks Design DeerSports with Outlast. They were designed for heated grips and work great. With the new gloves, I can't turn them up past 2 (out of 6) or my hands get way to hot at 40 degrees and 70 mph+ on the highway. I can't attest to how well they will hold up though, since they've only been on for about 6 weeks. They will get used a lot this winter though.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals, Andrews 26 Cams, Stage 1 intake, Krome Werks Heritage +2 bars, Progressive Monotubes, 444 hd's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Sancho's Wings, Mustang Wide Touring seat w/ CVO Backrest, Lowers with Classic Motorcycle Vents, Hogtunes 140w Amp, 5x7's & Tweeter Pod
Old 11-05-2012, 09:42 PM
Yellow09SERG Yellow09SERG is offline
Had my first set on an 06 Street Glide, installed them on an 08 Ultra, and now have them on my 09 Road Glide. I have had good luck with them on all 3 bike. I have found for me that they help even during the summer on those long rides when the hands get a little tired.
Old 11-05-2012, 10:19 PM
SurlyBoy's Avatar
SurlyBoy SurlyBoy is offline
I went with Symtec Heat Demon bar end heaters. About $110 on eBay, pretty easy to install and work with throttle by wire. The best part is you can run whatever grips you like
2012 Vivid Black Road Glide Ultra
Old 11-06-2012, 06:39 AM
glidethru's Avatar
glidethru glidethru is offline
My wife has had 2 sets on her Super Glide,the first set went bad and the the local dealership replaced at no charge.The second set went bad at the end of last winter,this time the dealership basically said you SOL. I sure as hell will not buy another set of Harley heated grips again.The gloves work well but are to bulky,but at least the Harley gloves have a lifetime replacement warranty.
2012 Big Blue Pearl Road Glide Ultra
HID lights
Windvest
RC Xhaust
Old 11-06-2012, 06:54 AM
Bull_Duck's Avatar
Bull_Duck Bull_Duck is offline
Went with the Gerbing heated glove liner. It can be used by itself if a thin glove is desired, with a glove shell, or regular glove. Important to have the thermostat controller 'cause they with merely the onn-off switch will get too hot.
The other Gerbing heated gear can be added. I have the vest as well. Cold weather is just another opportunity to ride.
2008 Road Glide 105th Anniversary - ours
2000 Deuce - mine. 1998 Dyna - hers
