11-05-2012, 02:42 PM
The 117 build has started.
Since yesterday was a typical gloomy NW kinda day, I decided to start on the 117.
The cases were split and cleaned along with removing the oil squirters and
looking for any machining chips left behind. Those got reinstalled with a small drop of Lock Tite on the screws.
The Dark Horse flywheel assembly was then cleaned and slipped into the pinion half of the case. 3 Bond gray sealant was applied to the primary case face and then installed onto the pinion half of the case.
All 9 case bolts were then torqued to the service manual specs.
I then mounted the case to the engine stand and checked both pinion and primary shaft run out. Both sides have .001 in. TIR.
Thats it for now.
http://i114.photobucket.com/albums/n...g?t=1352149078
2010 Vivid Black Road Glide Custom
11-05-2012, 04:09 PM
This is what scares me. You were at 106HP & 118TQ before and now your going bigger. I just finished installing a 107" kit & cams and I'm thrilled with the first 250 miles. Am I gonna end up wanting more?  What kind of numbers are you expecting with the 117"?
2009 FLTR MOP
"A Goverment should fear it's people not vice versa"
11-05-2012, 10:49 PM
Are you going to run the same heads? How about the exhaust?
Very interested in this build. Keep us posted!
11-06-2012, 03:27 AM
I hope it will make 120-125 hp and 130 torque.
Anymore than that is just icing on the cake.
I ate a little crow on the 107. I was hoping for 112-115 hp and 120 torque.
My 107 runs super, but there's this little guy that always sits on my shoulder
and whispers more MORE.
11-06-2012, 03:33 AM
I think your estimate is very realistic ~ I rode the owners bike of oasiscycles in Brandon, MS over a weekend ~ I did 1000 miles ~ they have a dyno room and that Ultra was 128/132 with a 117. Plenty of low end torque ~ I never rolled it over 4k .....
2012 FLTRXSE 113 Build ~ Chopped Tour Pack, Lowers, 13" Tinted MadStad, S&S Power Tune Duals Jet Hot Black, Daymaker LED's, Adaptiv TPX Radar Detector, Fork Baffle, Pro940's & Monotubes, Baker DD7, Zumo 660
Nope. I have a set of heads that Dan Baisley converted to his Pro Street specs.
I had him pick the cam and set the compression also.
T-man 662-1's and 10.8 comp.
I'm going to use a V/H Power Dual head pipe with a pair of Crusher Mellows and see how that works out. If not, I'll stick with the D&D Fat Cat.
When it's done I'll take it up to Russel at Lonewolf Performance and let him tune it.
We shall see.
11-06-2012, 03:39 AM
That's what I'd really like to end up at.
Russels dyno is conservative.
Do you know any of the build details of that engine?
11-06-2012, 04:16 AM
Not at all ~ the website is oasiscycles.com and Mark or Phillip can tell you about it. My understanding is that it was a low compression build ~ They do alot of custom builds and have three separate buildings on the property. Full blown side draft paint room, one is the shop which has a dyno room at one end of the building and the third is used to garage cool bikes and cars. The bike was set up for low end torque/touring. What you've done so far looks awesome ~ I am going to do some minor mods to my 110 but the dealer already changed a few things (his personal bike). Oasis did install the feuling camplate/oilpump/ and 777's for me in addition to a baker manaul primary chain adjuster on my 10 Ultra LTD with 70k on the clock. I was very happy with their work ~ Mark has a steet glide that is REALLY built ~ a 127 I think ~ they are very knowledgeable ~ I live in FL but will ride the 700 miles to let them do my Baker DD7....
11-06-2012, 04:36 AM
That Baker manual adjuster is on my list.
11-06-2012, 04:42 AM
I went through 4 SE Compensators on the 10 and figured I would give this a try ~ I am going to add the aim-tamachi louckout also.... I'll let you know how I like the DD7 ~ I figured I'll be keeping this bike alot longer than the 71k on the 10 or the 93k I had on the six, so why not. Plan on runnin a hundred k or so (3 years) and then doin a 117 or 120r ~ Have plenty of time & miles to decide ~ good luck with yours ~ can't wait to see the end results.
SemperFi
