PCV no start condition when cold... - Road Glide Forums
Old 11-06-2012, 01:56 AM
Exxon Valdez's Avatar
Exxon Valdez Exxon Valdez is offline
Default PCV no start condition when cold...
I have an '09 stock stage 1, 96" with a PCV with AutoTune. When the outside air temps are cold, around 40 degrees the bike doesn't start. Cranks fine, but won't fire up. I unplugged the PCV and reconnected the stock ecm and it fires up immediatly. Anyone else had this problem?
Thanks.
'05 BMW R1200RT
'09 FLTR (sold)
'84 FXR (sold)
Old 11-06-2012, 02:15 AM
Andyman's Avatar
Andyman Andyman is offline
A friend of mine had the same issue with her "07 Heritage. They replaced the PC and all was good. Until the stator went out. lol (unrelated)
'03 Deuce: 87k miles and counting, '11 RGU: 65k miles and counting. See y'all in Kerrville in June for SWV!
  #3
Old 11-06-2012, 09:09 AM
DED HD's Avatar
DED HD DED HD is offline
You might try hitting the starter button as soon as you turn the ignition on, dont wait for the light to go out like HD tells you to.
give fuel moto a call and they should be able to help.
'10 Red Custom:
check out my build thread for pix and mods http://www.roadglide.org/showthread....t=GR8FLH+Build
  #4
Old 11-06-2012, 11:31 AM
fuelmoto's Avatar
fuelmoto fuelmoto is offline
EFI tuning and Exhaust Expert
The first thing I would check is battery voltage, also check voltage drop at crankover. The PC-V requires about 9V to power up and if your battery is marginal and drops voltage excessively it may not be enough to power up the unit.
Jamie Long / Fuel Moto USA
Dynojet Power Vision info is here www.fuelmotousa.com/powervision.htm
The USA's source for EFI Tuning components and exhaust www.fuelmotousa.com www.jackpotmufflers.com
Contact 877-729-4754
Email jamie@fuelmotousa.com
  #5
Old 11-08-2012, 05:28 PM
Ok Thanks. Turns out that there was a batch of units up here that require a firmware update. We'll see if thats it. If not, I'm getting a new unit under warranty.
'05 BMW R1200RT
'09 FLTR (sold)
'84 FXR (sold)
