wheel help - Road Glide Forums
Old 11-07-2012, 09:34 PM
badboyindc badboyindc is offline
Default wheel help
Put on a 21" wheel and its on the stand it not moving free it like something is holding it back is it to tight or something bearing are be and use my stock spacers
Old 11-08-2012, 12:13 AM
rlaf75's Avatar
rlaf75 rlaf75 is offline
I dont have a 21" wheel but from what i understand is that you need to make the rear fender mounting holes larger so the rear of the fender can pick up alil and give you the clearance you need. Or at least loosen the fender bolts and make sure that is the problem before you drill them out
Old 11-08-2012, 12:19 AM
Stray Mutt's Avatar
Stray Mutt Stray Mutt is online now
Could be a dumb question, but did you confirm it's not rubbing the fender? There's about a 1/4 of slop in the struts that you need to max out to ensure clearance.
Old 11-08-2012, 06:34 AM
Peppa1's Avatar
Peppa1 Peppa1 is offline
Did you put the spacers back just like they came off ?
Old 11-08-2012, 10:28 AM
02heritage's Avatar
02heritage 02heritage is offline
Also make sure the spacers are ON the correct side. I know that on my 07 that one side is a little longer than the other. Although you should have seen a problem when putting the calibers back on.
2007 RG, 103ci, Harley Blade wheels, Painted Dash
Old 11-08-2012, 10:43 AM
laxinharley's Avatar
Theres supposed to be a little resistance there. Don't know what year but make sure your abs is hooked up properly within the tabs if you have it. Also like Rlaf75 said make sure your reem out your back holes on the fender, so you can tilt it up a bit.
Old 11-08-2012, 11:07 AM
CM_Jeff's Avatar
CM_Jeff CM_Jeff is offline
Not sure what bike the OP has but some of the Screamin Eagle models require a fender bracket to raise the fender.
Jeff Daugherty
www.coastalmoto.com
Old 11-08-2012, 11:35 AM
HogPro HogPro is offline
What year is your bike? Did you put new rotors and pads on too?
Old 11-08-2012, 01:36 PM
I added new rotors but not new pads you think the pads are to thick or some thing going to pull the rotors off and see if they spin free
Old 11-08-2012, 01:37 PM
my road glide is a 2005
