wheel help - Page 2 - Road Glide Forums
Old 11-08-2012, 01:39 PM
badboyindc badboyindc is offline
I dont think the fender is the problem going to pull rotors to see if that is the problem
Old 11-08-2012, 01:45 PM
staush's Avatar
staush staush is offline
I wouldn't pull the rotors just yet. Pull off the calipers first see if that helps. If it does then check clearances as you slide them back on. If they are tight then look at wheel spacers.
2011 Road- Glide Custom-stock engine w/K&N air filter. I like it quite.
Old 11-08-2012, 02:24 PM
thanks that just what i will do when i get home
Old 11-09-2012, 07:20 AM
Want to thank all the guys on this forum for your help the wheel spin smooth now took it apart change the spacers and it was fine thanks guys so much.
Old 11-09-2012, 07:21 AM
