Madstad final adjustment - Page 4 - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Windshields
Windshields Windshields for Road Glides
Sponsored by: Glide Air Deflector Systems
Old 11-08-2012, 02:06 PM
08gezzer 08gezzer is offline
How are you guys getting the angle with the measurement ?
I have mine at 2.5 bottom and 2.75 top
Angle is 50 degrees
2008 RG anniversary
You can teach a idiot , But you can't teach them much
Old 11-08-2012, 05:36 PM
Big_gary's Avatar
Big_gary Big_gary is online now
Angle is 50 degrees
Hows that setting working out for you. ?
10 FLTRX , Stage 1, 13" Madstad, Mono tubes, Heritage style bars
If I have to explain ,you wouldn't under stand anyway.
  #33
Old 11-08-2012, 06:15 PM
It was awful
2008 RG anniversary
  #34
Old 11-09-2012, 07:03 PM
Big_gary's Avatar
It was awful
Try 56 to 58 degree angle
  #35
Old 11-11-2012, 04:26 PM
Donkl Donkl is offline
Final adjustment was to remove 5 wellnut screws and replace it with a Cee Bailey. Works great now!
  #36
Old 11-11-2012, 05:12 PM
tdkkart tdkkart is offline
I ended up with top of the 13" shield 8" above the top of the radio eyebrow. Shield is spaced approx 2" from the base plate at the top, and on a 58* angle. I had been at 55*, 3* does make a difference.
Too bad i quit smoking, cuz now i could easily smoke behind the shield anywhere between 60 and 80 mph.
2011 Merlot RGU, 103", SE204 cams, Fuelmoto E-series 2-1, Ness BS, Power Vision, Progressive 940s/Monotubes, 13" MadStad.
  #37
Old 11-13-2012, 01:01 AM
I found mine has the dog dish thingy on the upper forks under the fairing, does anybody else have that with their madstad?
I also have the sancho wings and the deflectors
I am thinking the dog dish thing is causing more problems than its worth
I had to move my 16 inch madstad up where i look thru it to get the wind managable
It is at 57 degrees
2008 RG anniversary
  #38
Old 11-13-2012, 04:01 AM
4getNo1's Avatar
4getNo1 4getNo1 is offline
It is at 57 degrees
Don't have a Madstad (yet) and just watching this thread but regarding dog-dish style air dam, I think you're right.
It was OE on batwing types and directs some air-flow downward. For sharks, HD introduced the engine-guard type flaps to instead redirect some air upward behind our fixed fairing.
2013 FLTRX, Candy Orange
  #39
Old 11-13-2012, 06:46 AM
elbohead's Avatar
elbohead elbohead is offline
13" MadStad. Mounted it and adjusted it so I was looking over it (top about level with my teeth) and it worked great. I think I can probably go lower and be fine. I really can't believe how well this thing works.
  #40
Old 11-13-2012, 07:55 AM
Exxon Valdez's Avatar
Exxon Valdez Exxon Valdez is offline
My '09 came with the half moon air deflector only. I'm running a 13" MadStad at about mouth level, 1.75" gap at bottom, 56-57 degree angle, with the half moon deflector...amazed every time I ride the bike, how awesome this shield works. I'm 5,8" by the way.
'05 BMW R1200RT
'09 FLTR (sold)
'84 FXR (sold)
