LED vs HID - Page 6 - Road Glide Forums
Old 10-30-2012, 02:18 AM
dirtbag's Avatar
dirtbag dirtbag is offline
Originally Posted by cmacclel View Post
The HID's are going to be brighter with less gaps. The reason being is the factpry Halogen reflectors where not designed for HID lamps and when you install a HID setup your pretty much getting a flashlight style beam. The Daymaker LED's are setup not to blind people with a destinct cut-off like factory DOT approved HID lighting. Even if you say no one Flashes you odds are you are still blinding oncoming traffic unless you have your lights pointed abnormally low.
Projectors create clean cut offs and glare caps prevent the eye from directly seeing the plasma arc. It is common to use OEM projectors, bulbs and ballasts from Japanese and European cars which have a DOT approval to retrofit and use in other vehicles. Does that make it legal, no, but how the hell else are you going to put HIDs and an appropriate projector in a car that does not offer them? Bottom line: DOT is bullsh*t and HID mods can be done safely without some asinine sticker.
2010 FLTRX PAINTED & PC'D RED * CVO FASCIA - FRENCHED BILLET BOYS PLATE
BR CUSTOMS NEW WAVE II 1-1/2 X 12" BARS * PCV - PM SUPERGAS - V&H PROPIPE CHROME
AMSOIL 20W50 IN THE CRANKCASE/ATF IN THE PRIMARY/75W140 IN THE TRANS
http://www.v-twinforum.com/forums/en...tions-atf.html
ELITE III FRONT TIRE * AMERICAN ELITE REAR TIRE
Old 11-08-2012, 04:08 PM
Citykid's Avatar
Citykid Citykid is offline
Xardoz, what made you go with the 50/55's rather than the ultra slim HID kit?
Old 11-08-2012, 05:06 PM
dmize's Avatar
dmize dmize is offline
Going to pull the trigger on a set of the HID. Does this look correct?
http://www.hidsrus.com/harley-davids...dlights-bulbs/
Harley Davidson Road Glide Ultra Slim Digital HID Conversion KIT
Vehicle Year: 2010
Color: 6000k
Fitment: Dual Beam(+$18.00)
Warranty: Lifetime Warranty ($10.99)
Relay: Relay ($14.99)
Category: hidkit
Weight: 3 LBS
Not really sure what the options for the Fitment are:
Single Beam,
Dual Beam
Single Bi
Dual Bi
D.Mize 10 Vivid Black RGC
Old 11-08-2012, 07:08 PM
GMAN SERGU's Avatar
GMAN SERGU GMAN SERGU is offline
Vehicle Year: 2010
Color: 6000k
Category: hidkit
Weight: 3 LBS
Single Beam,
Dual Beam
Single Bi
Dual Bi
Hi DMize
That setup looks real nice and with lifetime warranty are great. It is not a big investment so they can be change if you do not like them. Lets us know how they look and maybe a picture before and after. Better than $700 and no replacement possibilities
Old 11-09-2012, 06:19 AM
tkbalt's Avatar
tkbalt tkbalt is offline
I had HID's installed soon after we purchased the RGC. The light is fantastic. Without projectors built for them, the lights kind of lit up the world, rather than being focused out on the road ahead. Different than what I was used to, not distracting - and great light.
I bought the LED's when they came out and have been happy with them. They are very bright, but seem more focused down the road. There is a flat cutoff that takes some getting used to. I notice it mostly when leaning into a corner at speed.
I don't regret the decision to go LED - but the HID's were a cost effective solution that worked perfectly.
Old 11-10-2012, 03:19 AM
4getNo1's Avatar
4getNo1 4getNo1 is online now
Thanks tkbalt, an excellent description of what you noticed as being different.
2013 FLTRX, Candy Orange
