Hell's Foundry Bracket - Road Glide Forums
Go Back   Road Glide Forums > Road Glide Specific Discussions > Road Glide Equipment
Road Glide Equipment Post Equipment Resources Here
Old 11-11-2012, 07:21 AM
Willy_B's Avatar
Willy_B Willy_B is online now
Default Hell's Foundry Bracket
Thinking of getting one. Any of you guys using them? How do you like them? How sturdy are they?
Old 11-11-2012, 07:47 AM
GoneBlack's Avatar
GoneBlack GoneBlack is offline
The hidden fairing mount? I've had mine for about 5K miles, love the clean look and ablility to remove my crash bar in minutes if wanted (mostly for pictures) as for sturdy, I only rode my bike with the factory setup for 170 before it was torn compelety apart but I have no rattles, shakes, shimmies, etc fairing is rock solid and for less than $100 I couldn't be happier
2012 Road Glide Custom....The build: http://www.roadglide.org/showthread.php?t=19311
CA spring Ride, book your room http://www.roadglide.org/showthread.php?t=26443
Old 11-11-2012, 08:30 AM
ybnorml's Avatar
ybnorml ybnorml is offline
Installed mine this past spring, and 12k miles later
they work and perform as advertised.
Old 11-11-2012, 09:01 AM
RoadGlide0611 RoadGlide0611 is online now
I put it on mine, works as advertised. Clean look, glad I put them on.
Old 11-11-2012, 09:08 AM
rlaf75's Avatar
rlaf75 rlaf75 is offline
I like the way the bikes look without the crash bar but having laid mine down ever so slightly on its side once im REALLY glad the crash bar was there.
Old 11-11-2012, 09:14 AM
I didn't do it to eliminate the engine guard. I did it to clean up the looks in the front. Also I do believe it blocks wind that comes up between the fairing and tank too.
Old 11-11-2012, 10:02 AM
HogWild's Avatar
HogWild HogWild is online now
2 years and 20,000 miles later, I still love mine. Also did it to clean up the front end. Very sturdy and no issues whatsoever.
Life is Good
Old 11-11-2012, 01:06 PM
Willy_B's Avatar
Thanks guys!! I just pulled the trigger and ordered a set. Can't wait. Now I can pull the engine guard off for powder coating and not lose and riding time.
Old 11-11-2012, 01:57 PM
skratch skratch is online now
so out of curiosity, if you have the hidden mounts, are you still able to run the snap on wind deflectors? do you even still need to?
Old 11-12-2012, 09:25 AM
kingjj kingjj is offline
Default Wind deflectors
No you can't use the, I can't feel a difference without them
Jerry King
USMC MSgt Ret.
