Building my own detacheable tour-pak rack - Road Glide Forums
Old 11-12-2012, 10:16 AM
GLYDDN11's Avatar
GLYDDN11 GLYDDN11 is online now
Default Building my own detacheable tour-pak rack
I have started building my own detacheable tour pak rack. I know...why you ask? 1: $180 for a new one through HD is riduculous in my opinion, 2: even if I bought one from HD I would still modify it.
One of the things I don't like about tour paks is how high they sit up. Yes I know that you can get a chopped pak or razor and it will be slimmer, but you lose some of your load capacity that way. So I wanted a shorter tour pak rack regardless.
So I talked to the guys in the machine shop at work and they are helping me with it. So far so good, it will sit about 1/2" off the fender which is what I wanted and it will have a little beefier support on the under side.
I have gotten the sides and the plates made and will be drilling the holes for the detacheable hard ware (got off Ebay for $25). It fits up to the attachment points perfectly ( I even got the plastic bushing dock pieces).
Hopefully I will have pics of the completed rack by the end of the week posted on here. I just wanted see if anyone else has tried or done this before.
The World ends when you're dead. Until then,
you got more punishment in store. Stand it
like a man....and give some back
Old 11-12-2012, 10:26 AM
Still Grumpy's Avatar
Still Grumpy Still Grumpy is offline
Picks will be cool as Im sure its going to look very cool and needless to say a One-Of-a-kind .
My only concern would be putting on the tourpak and the 1/2" clearance off the fender.
Trying to align the docking points while holding up that heavy pak is going to be a mother. . Make sure you have a buddy with you each time you put it on...
2013 FLTRX Road Glide Custom
2005 FLSTF Fat Boy
(Wife's but I ride it )
Old 11-12-2012, 10:36 AM
rlaf75's Avatar
rlaf75 rlaf75 is offline
Thats actually a great idea man. They do sit up high and it does take away ailil something from the bike. I bought the detachable TP mount awhile ago along with a cheap ass ebay trunk. Im probably gonna buy the yaffe chopped pak and mount it but getting lower to the bike would be pretty bad ass.
Old 11-12-2012, 10:39 AM
dmize's Avatar
dmize dmize is online now
If cost is a big decision factor, I've read some really good reviews on this bracket and its only $99
http://usa-biker.com/index.php?page=...hk=1&Itemid=28
If your looking to make something custom, sounds like a fun project...be sure to post lots of info!!!
D.Mize 10 Vivid Black RGC
Old 11-12-2012, 10:48 AM
rlaf75's Avatar
I think his goal is to lower the height of the bracket to make it sit closer to the fender. Had i known about this one though i wouldve jumped on it instead of buying the HD one for twice the money
Old 11-12-2012, 11:03 AM
JJSW1283's Avatar
JJSW1283 JJSW1283 is offline
Leave enough clearance to get the saddlebag lids open.
Old 11-12-2012, 11:20 AM
Jettjocky's Avatar
Jettjocky Jettjocky is offline
Smile
I guess if ya got the time "go for it", however, having said that, if it fails off, the loss of a $ 1,500 tour pak is yours. Good luck.
09 O/B CVO....Roller rocker arms, 10.5 pistons, HQ 575 Cams, SE adjustable push rods, Cee B., Rineharts, Mustang, Progressive front & rear, Moto Lights, HD LED Headlights, C & C Seat, Avon Grips,
HOGCOVERS
Old 11-12-2012, 11:37 AM
pargenz's Avatar
pargenz pargenz is offline
I'd like to re-design mine, not so much to make it removable or lower profile, but to make it compatible with a solo seat. Just to move it forward.
You know the one thing we need is a left-hand monkey wrench
Old 11-12-2012, 12:49 PM
GLYDDN11's Avatar
I believe that it will be stought enough to support the weight of the tour pak, I am putting two cross members on the underside for this purpose. I am putting a 1/4" rubber sheet inbetween the pack and the rack though as a vibration dampener so as not to cause anyproblems with the pack.
I have tested another tour pack sitting on top of it today and it leaves clearance to open the saddle bags if I am careful and don't just fling them up and open, but I usually don't do that anyways.
Please keep the opinions and suggestions coming cause I may have missed something.
As a few have said, its not so much a matter of cost as I want it lower. If I would have bought a HD rack I would have chopped and re-welded it back to lower it anyways. Plus it will be saving me a few dollars as I am making this for about $80 in expenses, not bad I don't think.
That one for $99 looks like a great deal for someone though.
Old 11-12-2012, 05:18 PM
rlaf75's Avatar
I think its a great idea and would love to see pics when you are done with it. Im thinking about chopping and lowering the HD one i have too
