11-12-2012, 02:25 PM
Again, I want if possible to buy and support a USA made tire, however there have just been too many long term (since Sept 08) ongoing issues with these tires,....... Dunlop, if you read these treads be advised, I have purchased many of your tires in the past, I realize things can go bad, but you have had had almost 4 years to FIX the issues with these tires and have elected not to do so,
When I called them in the past they would always discuss & try to resolve the issue, now when you call them they refer you to HD. I'm very surprised the motor company has put up with this situation as long as they have.
if & when Michelin makes this size, I will never buy a Dunlop again. I just hope in the meantime nothing really BAD happens, cause if it does, there is enough documentation, returns & no cost replacements at this point that you will not have a leg to stand on.
09 O/B CVO....Roller rocker arms, 10.5 pistons, HQ 575 Cams, SE adjustable push rods, Cee B., Rineharts, Mustang, Progressive front & rear, Moto Lights, HD LED Headlights, C & C Seat, Avon Grips,
HOGCOVERS
11-12-2012, 02:49 PM
Take a look- this is scary! Dealer won't touch it, gave me Dunlops #, even though a purchased the tire from them! Got to call Dunlop today and see what they say, Cross my fingers they stand behind their products but no holding my breath.
11-12-2012, 03:42 PM
this is something I know alot about. I didnt get 1k miles on my new bike before I noticed my front tire cupping and wearing like a 1" patch just off center of the tire. I complained and was blown off by my dealer. Then I brought the bike in for its 5k service and it showed even more wear, once again I tried to complain and he told me it was cause my air pressure was like 4 pounds low. (he did mention that this was a commom problem found in the Dunlop tire). I pretty muched figured that I was stuck with the tires and after I had so many problems just getting everything I paid for when I first bought the bike. (a story I will not get into). I had no fight left in me. I just wanted to ride my new scooter that I waited so long for. My dream bike. I walked into the dealer and bought my dream bike. Then had to fight for everything. now I am having to go in and replace my tires Both front and rear. My rear is so cupped that I feel in in the garage when I back out. the front now is shredding apart and now is not safe. I have 10,500miles on them both. I have heard everything from neck being loose to bad wheel bearings to something called fall-away? However, I am convinced that these Dunlap tires are s**t.
11-12-2012, 06:31 PM
I had a set of elite 3's on my road king that was the only set that I liked went mich commanders and the handling is much better no slip and slide on sealed road cracks or floating in a sharp curve I have tried a lot of tires and the commanders or the best handling will see how long they last
11-12-2012, 06:32 PM
SURE -- The # dealer gave me wasn't even a # for Dunlop!!! Go figure!! Emailed owners daughter, she is the HOG chapter dealer rep and since I am on the board and a road captain, maybe I'll get some action from her- HOPEFULLY??? Keep you all posted.
11-13-2012, 11:41 AM
I called Dunlop with the same issue cracking around the complete right side. , again I was told to take it up with my dealer. I was also told by them that the cracking was not a safety issue & not to worry about it. Guys I really believe there is a problem with these tires, & believe we as a group need to do something about it, I'm saving my front tire, & I am going to make some calls to see if it can be sent to a 3rd party to determine what is going on (of course at my own expense) I will report what information I obtain, based on that I may attempt to start some type of legal action,
l
HOGCOVERS
11-13-2012, 12:37 PM
Sure sounds like "yellow rain", I've heard the Seattle PD changes theirs (dunflops) to Metzlers from the get go, then the dealers sell them off. Anyway, tube or not, it is a safety issue, would the owners of the company ride around on split, substandard, poorly formulated, unavoidable excuse for ....
11-13-2012, 07:35 PM
Originally Posted by Jettjocky
My problem is the 09CVO RG..... FLTRSE3 uses
130/70b18
180/55b18
these tires are not used on the other 09 Screaming eagle bikes, or other 09s.
Dunlop makes the elite 3 in a size that fits the front, I ordered one on Monday. I don't know if it is a new size or not as I did not find it on my first round of tires. It is still a Dunlop, but maybe the side wall will stay together.
I still have not found a substitute for the rear, for now we are stuck with the OEM tire.
11-13-2012, 10:46 PM
I did not know that thanks for info, however as I suspect you are aware changing tread patterns from front to back is not recommended, but again thanks for info.
HOGCOVERS
11-14-2012, 12:18 AM
Where (or rather who) is it NOT recommended to change tread pattern between front and back - I've never heard of this before
2011 Vivid Black RGU; Crusher Power Cell, Street Sleeper II A/C, Kury TC-24 cams, BAL, SEPST, Headlight Modulator, Damn big smile
