Adjusting shifter... - Page 2 - Road Glide Forums
Old 10-28-2012, 08:15 PM
idahointrudr's Avatar
idahointrudr idahointrudr is offline
Originally Posted by bucketlisthd View Post
I recently stripped the front shift lever 60 miles from home on back roads. (lotsa shifting) I managed to get home using the rear lever for both up & down shifts.
Woulda been tough with only one lever. I use the rear lever exclusively for upshifts anyhow, so it's stayin'.
Thats good info. I could never get used to using mine ,on any of my bikes.
I wonder if you could put the rear shifter up front. Reverse the pedal part. If thats the case I would throw the rear in the saddle bag. That way I would have a back up?
2009 Blue Road Glide,12" Apes, stage one, Screaming Eagle Pipes, Air Deflectors, Mad Stad 13" shield, Sancho Wings, Painted Lowers, Heated seat and grips, Kuryakyn Driving Lights
1998 Suzuki 1500 Wifes
2001 Suzuki 1500 Mine
2003 Goldwing Mine
2008 Goldwing Wifes
2009 Roadglide :>)
Old 10-29-2012, 02:25 AM
danglide danglide is offline
front and rear shifters are the same part .I took em both off and compared.I used the kuryakyn spacer and moved the front one outboard.
2012 FLTRU-Thunderheader,T-max,tuned induction,progressive monotubes
Old 10-29-2012, 06:47 AM
bucketlisthd's Avatar
bucketlisthd bucketlisthd is offline
Yup, same part front & rear. Alot of folks don't like the rear shifter. Personally, it's all I use for up-shifts.
Those bolts are tight! I used a 3/8 drive allen gizmo & a 1/2 drive adaptor on a 1/2" ratchet. That did it. I was on a mission as the front lever was completely stripped. It was coming off one way or the other.
"09 Roadglide
'87 FXR 100"
'79 Goldwing cafe
Old 10-29-2012, 09:22 PM
Good to know. Thanks
2003 Goldwing Mine
2008 Goldwing Wifes
2009 Roadglide :>)
Old 11-13-2012, 11:02 PM
bikerglasses's Avatar
bikerglasses bikerglasses is online now
Adjusted mine and much better, actually alot easier to find neutral now. I haven't started using the heel toe shifting.. we'll see..
Ian -- Tucson, Arizona
2013 Street Glide - Denim Black - ABS/Security w/ Cruise
