2012 fltru stock cam numbers - Road Glide Forums
Old 11-14-2012, 07:23 AM
DOOFUS's Avatar
DOOFUS DOOFUS is offline
Default 2012 fltru stock cam numbers
I looked but cannot find it on here -- does anyone know the numbers for our stock cam on the 2012 FLTRU? I'm trying to compare to the TW-222 regarding lift/duration etc. Thnx, DOOF
Safety Moderator / IBA# 22419
100,000k+ HD Miles
Old 11-14-2012, 07:52 AM
tdkkart tdkkart is online now
Check here:
http://bigboyzheadporting.com/tccams.htm
In the drop down select HD injected 07-09.
This came up on a forum a couple weeks ago, and nobody could come up with any newer numbers.
Pretty much the numbers could be labeled as "piss-poor".
Old 11-14-2012, 08:51 AM
11Roadie's Avatar
11Roadie 11Roadie is offline
You can also find them in the HD SE Parts catalog that can be downloaded from the HD website. Shows a numbers chart comparing a few SE cams too. I have the 204's in mine.
2011 FLTRU
PCV w/AT
K&N Air Filter
Cobra Power-Port Headers/Rush Mufflers
SE 204 Cams/Fueling Lifters/S&S Adj. Pushrods
Old 11-14-2012, 10:06 AM
Tony G...PFFP's Avatar
Tony G...PFFP Tony G...PFFP is offline
Default cams
iv got a 20011 with the SE stage 2 big bore kit (103) i believe the same kit is on the 2012 (???) i have the spec sheet, its showing SE255...lift 556/556...duration 211/235...don't quote me though, HD should give u a motor parts list if u ask them.......PFFP
Old 11-14-2012, 12:44 PM
DOOFUS's Avatar
Thnx crew !
100,000k+ HD Miles
Old 11-14-2012, 04:44 PM
rcpops53's Avatar
rcpops53 rcpops53 is offline
Thumbs down
Ok.....let me get this right....my 2011flhtru came w/255's and the Stealer, sold me 255's to hop up my new ride , before delivery ?
Old 11-14-2012, 05:17 PM
panhead's Avatar
panhead panhead is offline
I dont believe the 103 come with the 255 cams..The 96 and 103 have the same cams (milder) from the factory. I am told the 110 Screamer Eagles do come from the factory with the 255s.
2011 COOL BLUE PEARL FLTRX , 120R, Dragula 2 into1, WO572 14" chubbies,12'' windvest. Too much to list....... Basically a bottomless money pit that I love to ride!
Old 11-14-2012, 05:21 PM
11Roadie's Avatar
No, CVO models only came with the 255's stock.
2011 FLTRU
PCV w/AT
K&N Air Filter
Old 11-14-2012, 06:35 PM
Default cams
my apologies i forgot to tell you i bought my bike with a 96" ....then did the upgrade...so the 103 kit comes w/SE255...like i said I'm not sure what the factory 103 came with...sorry if i messed you up..........
Old 11-14-2012, 07:35 PM
DOOFUS's Avatar
Ok - I found the SE Catalog showing the stock 103 cam numbers:
100,000k+ HD Miles
